Low Voltage Bracket With Old Work Box - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 10:10 AM   #1
Rewards Points: 342
Question
Low voltage bracket with old work box
Do they make a low voltage bracket like this:
http://www.amazon.com/Thomas-Betts-S...7219223&sr=8-9
That works with an old work box like this:
http://www.amazon.com/Thomas-Betts-B...7219360&sr=8-2
Because Lowes didn't seem to have have one that works?
tripower is offline   Reply With Quote
Old 06-22-2010, 10:50 AM   #2
Licensed electrician
Rewards Points: 1,884
You should be able to buy a Carlon Super Blue 2 gang box and install the divider panel between the two gangs.
Arlington, www.aifittings.com may also have what you need. Look at the retrofit TV boxes.
Old 06-22-2010, 10:55 PM   #3
I don't think T&B makes plastic device boxes any more since they bought Carlon. See page 40 of this PDF catalog from T&B for an image and part number options. It does say the add-on ring works with retrofit applications as well so you should be able to just use a Carlon box with no issues.
brich is offline   Reply With Quote
voltage regulation problem - big voltage drop when load applied rnice Electrical 8 12-13-2009 08:43 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
Making 2rpm motor spin slower? mikehende Electrical 24 12-03-2007 10:23 AM
