Old 08-11-2008, 04:46 PM   #1
Low voltage box question
Hello:
For this detached garage/studio I'm wiring I have to install some low voltage bell wire for the garage door sensors and opener. I know that you're not supposed to run low voltage and high voltage wiring through the same holes, and I'm good there. I was planning to run the low voltage wiring through standard blue high voltage boxes. There won't be high voltage wires in the box, I just want to use that type of box for the low voltage wires. Is that okay, or do I have to use the fancy orange (and more expensive) open back low voltage boxes like I see at Lowes?
Thanks.
Shawn Marshall
Portland, Oregon
WShawn is offline   Reply With Quote
Old 08-11-2008, 05:39 PM   #2
Better yet just use a single gang ring screwed to the stud, no box needed.
Steven Jackson is offline   Reply With Quote
Old 08-11-2008, 07:13 PM   #3
Electrician
Originally Posted by WShawn View Post
Hello:
Sure you can.
Thanks.
Shawn Marshall
Portland, Oregon
Sure that will work.
chris75 is offline   Reply With Quote
Old 08-11-2008, 07:26 PM   #4
Moderator
Termite's Avatar
The current code requires a 20 minute membrane separation between the house and the garage, and further requires that all structural elements (walls, posts, etc) supporting the surrounding structure. Anytime an electric box is put in a fire separation, it needs to be an appropriate box for the application. Since they don't make 20 minute boxes, the electric box will have to be a one hour box (which is a pretty standard box, with a few exceptions). Most plastic boxes that you find at home improvement centers are 1 hour rated. Mudrings or those plastic low-voltage boxes without backs on them carry no fire resistance rating, and are therfore not to be used in garages. Low voltage and home automation installers make this mistake on a regular basis! Installation of electric panels, alarm panels, or other electric boxes over 16 square inches (opening dimension) in the garage sheetrock is a no-no due to the added potential for passage of heat and fire in the event of a garage fire.
Old 08-11-2008, 08:03 PM   #5
Cow
Seems like a moot point thekctermite since it's a detached garage.
A plaster ring(mud ring) with low profile screws works well. Or just cut the backs off regular nail on boxes.
Cow is offline   Reply With Quote
Old 08-11-2008, 11:02 PM   #6
Moderator
Termite's Avatar
Uh, yeah....I totally missed that detached part! I think I need to read more slowly! Sorry for any confusion!
Old 08-19-2008, 12:51 AM   #7
Hi:
Thanks for the replies. I'll probably go with some shallow blue boxes.
The info regarding fire separation does sort of apply to my situation, even though it's a detached garaged. Two of my walls are only a foot off the property line, and thus I have to have one hour fire resistive walls on those two sides with 5/8" wallboard on the interior and exterior and no openings to the exterior. I'm using standard blue plastic boxes in those walls, which I guess should be okay if they're rated for an hour.
Shawn Marshall
Portland, Oregon
Old 08-19-2008, 07:22 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Why are you even using boxes for the lo-vo stuff.
Just for looks?
I've never seen anybody use boxes for the sensor and button wiring.
Speedy Petey is online now   Reply With Quote
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Low voltage wire entering/exiting walls need box? Azeiku Electrical 2 07-07-2008 05:55 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
low voltage lighting question please.. melissadurante Electrical 1 03-02-2008 01:55 AM
