Low Voltage Between Line And Neutral In Oven - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 05:19 PM   #1
Unhappy
Low voltage between Line and Neutral in Oven
Hello,
The oven in my Wolf cookstove stopped working some time back. I called the authorized repair person who told me that the problem was electrical.
The voltage between each of the two lines and ground is 110 volts each (what it shoud be); but the voltage between each of the two lines and Neutral is only 20 volts. The repair person claimed that this was the probelm and that an electrician could fix it easily.
I had replaced the circuit breaker (50 Amps) to try and fix the problem but that did not help.
Any advice?
Thank you,
Nitin
ni44mi is offline   Reply With Quote
Old 02-10-2012, 05:22 PM   #2
check for a loose neutral in the receptacle box and main panel.
MitNotrof is offline   Reply With Quote
Old 02-10-2012, 06:43 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,202
You have a faulty neutral line !
Check the connections at both ends,
Then check the cable itself !
Most likely fault is loose connection !
Probably in panel.
dmxtothemax is offline   Reply With Quote
Old 02-12-2012, 01:06 PM   #4
Thank you both for the quick responses. I will ask an electrician to check the panel in the garage first, and then look at the oven next.
Nitin
Tags
electricial , line voltage , neutral voltage , oven
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
How do you measure DC voltage without a negative DC line (smoke detectors) darlingm Electrical 22 01-22-2012 10:25 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
