Low Voltage?? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2008, 05:07 PM   #1
low voltage??
I bought a house and I was told that a couple of the swithces were low voltage that control some lights. what does this mean and can I switch to normal swithces? I will be glad to give more info if needed and I can answer it.
thanks
couchguy is offline   Reply With Quote
Old 12-16-2008, 06:18 PM   #2
A low voltage system uses a transformer to step down the input voltage to a lower voltage(usually 12V) to the lamps. It depends how your system is wired and what you what to do. Can you post some pics.
jerryh3 is offline   Reply With Quote
Old 12-16-2008, 06:53 PM   #3
There is also a system that uses low-voltage switches to control relays that control 120V lighting. You might find this type of system in an older house.
Matsukaze is offline   Reply With Quote
Old 12-16-2008, 08:50 PM   #4
how can I tell if it is a low voltage switch, or if low voltage is going to the switch.
Voltage drop fix I discovered... rgsgww Electrical 12 12-09-2008 05:21 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 09:01 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 09:38 AM
