Low Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 10:14 PM   #1
low voltage
how does a low voltage circuit, e.g. garage door opener button, receive power and send the command back to the unit over the same two wires?
johnpaul1 is offline   Reply With Quote
Old 04-05-2008, 10:28 AM   #2
Idiot Emeritus
Rewards Points: 1,492
On a two-wire setup where there's only one button, the button is a simple switch. Just like a light switch.
On a two-wire garage door opener control with more than one button, there's always a small steady current flowing through wires to the push-button station. When a button is pressed, it sends a specific pulsed signal (different for each button) back up the wires. The motor part sees this, and does what its told.
Rob
micromind is offline   Reply With Quote
Old 04-05-2008, 12:19 PM   #3
Rewards Points: 2,350
There are a couple of ways this can be accomplished. One is what micromind details, different pulse widths can be detected by a circuit in the device being controlled. You could also have different buttons have different resistances. For example, there may be a constant 10 M resistance between the two wires. When you press button 1, it drops to 10 k. When you press button 2 it drops to 50 k. A circuit in the device can tell which button was pressed by the resistance across the two wires.
InPhase277
Old 04-05-2008, 12:39 PM   #4
I would think that a simple latching relay would do the same thing...
KC
kencaz is offline   Reply With Quote
Old 04-05-2008, 12:49 PM   #5
KC
For more than one function? That would probably require at least 3 wires for two relays.
InPhase277
Help! Need way to locate low voltage light cables Johnboy555 Electrical 17 01-13-2017 01:34 PM
Low voltage & mega kilowatt usage sdswcs Electrical 29 10-18-2013 08:22 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 09:01 PM
High- or Low- Voltage?! Cypherson HVAC 2 10-29-2007 09:32 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 09:38 AM
