Old 03-21-2011, 11:27 PM   #1
Doing it myself
Alan's Avatar
Low volt question (RG-6 cable & shorts)
I was at the hardware store looking for a pocket toner to figure out this mess of dish network cables running everywhere in the new house so I can hook my TV and modem to one of them inside the house, and tell the cable guy which one to connect to the box outside of the house.
This guy from the phone company tells me I should just 'short' the end using a barrel connector and then use a regular multi-meter on the other end to find it.
How do I go about accomplishing shorting an RG-6 cable?
Journeyman Plumber
Old 03-21-2011, 11:37 PM   #2
I would simply cut off the connector, strip it, connect the inner conductor to the shielding, then test for continuity. Place new connector on the end when finished.
jlmran is offline   Reply With Quote
Old 03-22-2011, 12:03 AM   #3
Tool Geek
PaliBob's Avatar
Here is a neat Tester from Amazon.com
& Stay Safe
.....Bob Lavery
Old 03-22-2011, 01:56 AM   #4
nap
You talking to me?
nap's Avatar
with one of these:
http://www.amazon.com/Type-75-Ohm-Te...bxgy_hi_text_c
. You will have to also get a female to female coupling (external threads on both ends). Screw into the F connector on the cable and screw the terminator on the other end of the coupling.
Old 03-22-2011, 02:11 AM   #5
  • make a jumper from a short piece of wire and two alligator clips - clip to center conductor and shield at one end to short, check with ohm meter or continuety tester at other end
  • buy jumper as above from Radio Shack or elsewhere
  • use a barrel connector, wrap or solder a wire to short one end
  • use a couple paper clips as jumper...
lots of quick and inexpensive ways to short one end of the cable...
Old 03-22-2011, 05:43 AM   #6
Semi-Pro Electro-Geek
If it already has an F connector on it, you can usually bend the inner conductor against the connector shell, sticking the tip against the threads to make it stay.
mpoulton is offline   Reply With Quote
Old 03-22-2011, 07:30 AM   #7
Tool Geek
PaliBob's Avatar
Here is the Coax Coupler
Amazon says they have 8 in stock. Let's see that should come to
And that's for what Amazon calls the Premium model.
& Stay Safe
.....Bob Lavery
Old 03-22-2011, 11:50 PM   #8
Doing it myself
Alan's Avatar
Originally Posted by nap View Post
with one of these:
I didn't know that would short it. Good call. Cheap radio shack device.
Journeyman Plumber
Old 03-23-2011, 12:02 AM   #9
nap
You talking to me?
nap's Avatar
that's a termination resistor. It should allow a read through of the characteristic impedance which is 75 ohm for rg6
Old 03-23-2011, 11:19 PM   #10
Doing it myself
Alan's Avatar
so when I check the other end I should place the test leads 1 on the center conductor and one on the outside of the fitting and I should read 75 ohms, right?
Journeyman Plumber
Old 03-23-2011, 11:21 PM   #11
Or check for continuity. Uses a tone (beep) on a digital meter.
What kind of meter do you have?
Old 03-24-2011, 12:56 AM   #12
Doing it myself
Alan's Avatar
I've got a craftsman digital, and it has both functions, so I should be o.k. either way.
Thanks all.
Journeyman Plumber
confused about,208/240 lionking Electrical 10 10-26-2010 10:54 PM
Underground Cable Question Livewire78 Electrical 7 12-09-2009 01:15 PM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
