Low volt question (RG-6 cable & shorts)
I was at the hardware store looking for a pocket toner to figure out this mess of dish network cables running everywhere in the new house so I can hook my TV and modem to one of them inside the house, and tell the cable guy which one to connect to the box outside of the house.
This guy from the phone company tells me I should just 'short' the end using a barrel connector and then use a regular multi-meter on the other end to find it. How do I go about accomplishing shorting an RG-6 cable? :huh: |
I would simply cut off the connector, strip it, connect the inner conductor to the shielding, then test for continuity. Place new connector on the end when finished.
1 Attachment(s)
Here is a neat Tester from Amazon.com
http://www.amazon.com/Type-75-Ohm-Te...bxgy_hi_text_c . You will have to also get a female to female coupling (external threads on both ends). Screw into the F connector on the cable and screw the terminator on the other end of the coupling. |
If it already has an F connector on it, you can usually bend the inner conductor against the connector shell, sticking the tip against the threads to make it stay.
1 Attachment(s)
Here is the Coax Coupler
Amazon says they have 8 in stock. Let's see that should come to 8¢ And that's for what Amazon calls the Premium model. . |
:thumbup::thumbup::thumbup:Thanks :) |
What kind of meter do you have? |
Thanks all. :thumbup: |
| All times are GMT -4. The time now is 11:36 AM. |
