Old 12-08-2012, 01:12 PM   #1
Low power from an electrical outlet
I have two outlets on the same circuit that register low power on a tester however does not operate a light, etc when plugged in. Any suggestions.
Rcurry is offline   Reply With Quote
Old 12-08-2012, 02:18 PM   #2
Civil Engineer
I am not certain exactly what you mean by "low power". Since the outlet does not work, it most likely has no power at all. You could be picking up phantom voltage, which could register as lower than normal voltage on a voltmeter. If you describe exactly what you measured, and how your measured it, it would be a lot easier to figure out what is happening.
Power Outlet that stays off when power fails hachadwick Electrical 9 01-11-2013 11:38 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
No power in outlet sherben2 Electrical 16 03-19-2009 12:35 PM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
