-   -   Low power from an electrical outlet (http://www.diychatroom.com/f18/low-power-electrical-outlet-165918/)
Rcurry 12-08-2012 12:12 PM
I have two outlets on the same circuit that register low power on a tester however does not operate a light, etc when plugged in. Any suggestions.
Daniel Holzman 12-08-2012 01:18 PM
I am not certain exactly what you mean by "low power". Since the outlet does not work, it most likely has no power at all. You could be picking up phantom voltage, which could register as lower than normal voltage on a voltmeter. If you describe exactly what you measured, and how your measured it, it would be a lot easier to figure out what is happening.
