Low Ceiling Shower Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 07:43 PM   #1
Rewards Points: 410
low ceiling shower lights
I'm starting to wire the basement bath
I have a 6 foot ,4 pc walk in shower I'm going to install in the basement soon.
I would sure like to have a couple of lights in there but it would have to be
inside the space of a 2x4 ceiling ( I'm right under the furnace runs).
Also its only 6 foot 9 inches to the ceiling.
Maybe a low voltage light would work ??
Any ideas??
High Gear is offline   Reply With Quote
Old 02-26-2010, 08:23 PM   #2
Registered User
Termite's Avatar
That's a tough one. Are you wanting something recessed in the 2x4 space? Or something that surface mounts?
Puck lights could be a possibility, but you'll need to find something rated for wet use.
Old 02-26-2010, 08:31 PM   #3
Rewards Points: 410
Yes something that maybe mounts flush inside the space.
Don't really want to put in 2x6 as I would like all the headroom I can.
As it is the top side of the 2x4 would be 1 inch below the heat runs.
I plan to cement board and tile the ceiling.
I hate dark showers.
Old 02-26-2010, 09:24 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Bear with me a moment but I did recall someone did make a low profile horzontail bulb shower luminaire set up but I am not sure if they still making it now or not oh yeah .,, it is not a round glass format it will be square glass format but one of us should come up with an answer so hang on for a montment.
Merci.
Marc
Eliminating can lights from a heated ceiling with a popcorn finish. Level Joe Electrical 3 12-16-2009 01:53 AM
shower curtain rail, but sloping ceiling Hazel Interior Decorating 2 11-07-2008 04:46 AM
ceiling & wall lights diynovice1 Electrical 5 07-30-2008 02:10 PM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 03:38 AM
halogen lights fitted into a polystyrene ceiling - safe? jono_wales Electrical 1 03-07-2005 02:52 PM
