Old 06-14-2011, 01:21 AM   #1
Lots of wires in mystery box
There are 2 two-wire cables coming into this one box and one three-wire. I have no idea why. It is near the floor so there must have been outlet here before. There is a light fixture on the ceiling and a switch nearby. Can anyone make any guess as to what is going on here? All the other outlets in the house are straightforward with 1 pair coming in and 1 pair coming out.
djgrant is offline   Reply With Quote
Old 06-14-2011, 01:26 AM   #2
It feeds other receptacles, or lights, I'd say. Was there a receptacle in this box?
The three wire indicates a possible 3-way switch
Old 06-14-2011, 01:30 AM   #3
I'm not sure, probably was a receptacle.
Oh I see...like there is one coming in and two going out.
So the one that confuses me now is the 3 wire. It's red wire has a cap in the end and it is not connected to any other wire in this box.
Old 06-14-2011, 01:36 AM   #4
Well, I mean, was anything there, or has it always been like this (opened; no cover on it)?
Why are you looking into this? It could simply be a junction box, or a receptacle was there at one time, and someone covered it.
The RED wire may have been for a ceiling fan/light at one time, or it could be part of the travelers for a pair of 3-way switches.
Old 06-14-2011, 01:39 AM   #5
Are you wanting to add a receptacle to it? If so, you'd need to check with a voltmeter if there's 120v between the group of White wires and the group of Black.
ALSO, I see a wire (looks like a bare wire with white paint on it) coming out the right side of the box; what is this?
Old 06-14-2011, 01:43 AM   #6
I'm really not sure the history of it. There was an electrician in that room and another room doing electrical stuff for the new furnace and heat pump. He also added a couple outlets that I wanted and I gave him free reign to fix up anything he saw. We were on vacation while this was all going on. I suspect he added the outlet because it looks like his work.
Old 06-14-2011, 01:45 AM   #7
The three wires coming out towards us are pigtails for hot, neutral, and bare (with some paint in it)
Old 06-14-2011, 07:22 PM   #8
I would say there was a outlet there, and one of the outlets was on a switch. See if there is a red wire in your switch, or just see if it is hot when the light is on only.
psuryan is offline   Reply With Quote
Old 06-15-2011, 04:38 AM   #9
the other possibility is that the dude simply ran out of 14/2 or 12/2 and had to use 14/3 or 12/3.
AndyinAtl is offline   Reply With Quote
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 12:20 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
a wiring mystery jgm156 Electrical 15 10-04-2009 07:32 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
