Lost Power To Half The Room. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 01:09 PM   #1
Lost power to half the room.
Hello everyone I dont know how but I have lost power to outlets in half of my room. I replaced a regular light switch with a motion detecting light switch in my bathroom. I cut off the power to the room and swapped out the outlets making sure to disconnect and reconnect the wires correctly. when i turned the power on the motion light works fine but I have lost power to the outlets on one side of my bedroom thats connected. I attached a pic to give a better understanding.
imfocused is offline   Reply With Quote
Old 04-09-2010, 01:33 PM   #2
Master Electrician
Rewards Points: 3,698
Check the receps when the light controlled by the motion sensor is on. You may have mis-spliced the wires in the switch box.
brric is offline   Reply With Quote
Old 04-09-2010, 02:17 PM   #3
i put the motion switch to the ON position but still got nothing, my next step is to install a normal switch to see if there is not enough power to power a motion switch and the outlets.
Old 04-09-2010, 02:30 PM   #4
Just call me Andrew
Rewards Points: 1,020
You probably just have a loose wire at one of your outlets,and it could be at one of the working outlets. Not really such thing as not having "enough" power to use a motion sensor and outlets. Outlets don't use power - just the devices plugged into them.
Andrew
secutanudu is offline   Reply With Quote
Old 04-09-2010, 03:28 PM   #5
could it be that the wire nuts are to big and not tight enough?
Old 04-09-2010, 03:32 PM   #6
Just call me Andrew
Possible. Check each outlet for loose connections. In particular, look for "backstab" connections, where the stripped part of the wire is simply stuck into the back of the outlet (no screw is tightened in these connections). Consider replacing those with "backwire" connections, where you slide the wire under a clamp and tighten the screw.
Usually when a bunch of stuff stops working, a wire is loose somewhere.
Andrew
Old 04-09-2010, 04:00 PM   #7
Master Electrician
If the only piece of equipment that you've had apart is the switch then definately start there....double and triple check everything in that box. It would be a pretty wild coincidence if another fault on the line just happened to occur when you swaped out the switch.
andrew79 is offline   Reply With Quote
Old 04-09-2010, 04:40 PM   #8
I tried switch a regular switch thats in the bathroom with the motion switch and got no lights in the bathroom or bedroom at all! but when i put them back the way they were evrything went back to how it was except still no power to the outlets.
Old 04-09-2010, 04:56 PM   #9
Master Electrician
It's very hard for anyone here to help you without a more complete description of what you have done. Perhaps some photos would help.
Old 04-09-2010, 05:11 PM   #10
There is a diagram up top. really all i did was install a motion detecting switch in my bathroom wired it up the to black > black. black > red, Green > ground. and it works fine in the bathroom. all my wires from my wall were black so i made sure to put the ground wire to the side.
Old 04-09-2010, 07:00 PM   #11
Question
Then there would be another problem. Overheating wires. Could be dangerous. But the effects of a loose connection would be flickering lights that are plugged into the outlets or intermittent contact.!
spark plug is offline   Reply With Quote
Old 04-09-2010, 07:00 PM   #12
joed's Avatar
Rewards Points: 11,614
The motion detector didn't have a neutral?
Check for neutral connection in the switch box that has come loose.
In your first post you said you swapped out the outlets. Now you are saying you only changed the switch. Which is it? You have a loose or open connection somewhere.
Old 04-10-2010, 10:30 AM   #13
sorry for the confusion I changed out the switch.
Old 04-10-2010, 12:05 PM   #14
ok so here is a pic of the wiring. Note that all my wiring is black.
Old 04-10-2010, 02:34 PM   #15
joed's Avatar
Is that green connected to a black wire? It should be connected to the bare wires. The black wire is the power to the receptacles and should be connected one of the other black wires.
On the original switch, two of the blacks must have been connected to the same screw. One of those black is power in and the other is power to the dead receptacles.
advice/Help on non-permitted bonus room? Orange_County General DIY Discussions 43 06-11-2010 06:06 PM
Random weak/no power. madmatt Electrical 4 05-10-2009 01:04 PM
On bloody HOT room. rahlquist HVAC 30 04-20-2009 08:50 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
