Lost Power - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 08:53 PM   #1
lost power
I went to turn on the vacuum and the power went off. I went downstairs to check the breakers and none was tripped. I clicked the breaker for the room and still nothing. What could be wrong?
cindypit2559 is offline   Reply With Quote
Old 12-20-2011, 08:58 PM   #2
Rewards Points: 6,652
What room is this outlet in?
Old 12-20-2011, 08:59 PM   #3
jproffer's Avatar
Rewards Points: 716
Did you turn the breaker off and then back on again? A breaker won't move directly to the on position from the tripped position.
jproffer is offline   Reply With Quote
Old 12-20-2011, 08:59 PM   #4
Licensed electrician
Rewards Points: 1,766
You could have a loose connection.
Old 12-20-2011, 09:02 PM   #5
Rewards Points: 506
Are you sure the power went off? Perhaps the vacuum died? Did you call the power company? Maybe an outage coincidentally occurred when you turned on the vacuum? GFCI?
There are a lot of assumptions to be made based on the symptoms you present.
jlmran is offline   Reply With Quote
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
outlets lost power Hoegy Electrical 5 11-06-2007 02:06 PM
Garage lost power jkrodger Electrical 4 11-04-2007 08:50 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
