Lost Electrical Power - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 12:46 PM   #1
Angry
I installed a new ceiling light fixture to my kitchen and conected it to a wall light switch. All working work perfectly this past weekend. Since it stopped working I disconnect the fixtue and switch and tested the wires...I am no longer getting powere to the wires. The circuit breaker is hot.
mtouset is offline   Reply With Quote
Old 05-04-2011, 12:57 PM   #2
I=E/R
a7ecorsair's Avatar
Is power fed to the fixture with a switch leg going to the switch or is the power at the switch first?
a7ecorsair is offline   Reply With Quote
Old 05-04-2011, 01:50 PM   #3
Your power feed may enter the light first then a leg to the switch. You should (turn the breaker off) then remove the light fixture and inspect your connections. If you have good connections then odds are there is no power getting to the light (or else you would see it at the switch) then you will need to start tracing it back to the panel to find the root cause.
bhennon is offline   Reply With Quote
Old 05-04-2011, 02:42 PM   #4
Thanks. You've validated my fear that I would have to trace back to where the loss of power is. The power does enter the light fixture first and legs to the switch the switch. In either case there is no power to any of the wires although the breaker is hot. Unfortunatly I've exhausted my knowledge when it comes to electricity so I have no clue as to how I trace to the root of the problem. In my mind there are two kinds of homeowners: The DIY folks and the people that have the ready means to hire professionals. I fall into the former category.
Run electrical through foundation to power lamp posts? Drywater Electrical 4 12-08-2010 11:39 AM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Do electrical breakers lose power? Patti Electrical 8 03-16-2008 12:08 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
