Lost Electrical To Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 12:19 PM   #1
Lost electrical to garage
I want to replace wiring that runs from house to garage. Wiring was done in 50's and lost power at garage. Power at out bound of house is good, but does not make it to garage. I do not know proper gauge or if I should use conduit or PVC. 50 ft away from house. Plan is to abound old and start over. Old run runs under sidewalk. Garage is 2 car two door with openers on each. Motion light, porch light near door. 2 outlets and two lights. nothing big is used in garage, looking for standard garage advise. Thank you
flyer1 is offline   Reply With Quote
Old 04-17-2013, 12:24 PM   #2
Rewards Points: 2,516
Are you saying the wiring does not make it to the garage? That could be your problem there.
hammerlane is offline   Reply With Quote
Old 04-17-2013, 12:26 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Sounds like the power exiting the house is live but not when it gets to the garage. I run some conduit and wire to the garage depending on what you plan on running there.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-17-2013, 01:24 PM   #4
Correct, wire is live at house dead at garage.
Old 04-17-2013, 01:33 PM   #5
Want to abandon the old run, there are different gauge wires from start to finish of old run. I want to start a new run with proper wiring.
Old 04-17-2013, 02:21 PM   #6
rrolleston's Avatar
You will have to determin what is currently feeding the garage now and decide what you want to run so you can figure out what wire to run.
Old 04-18-2013, 08:44 AM   #7
Garage is 2 car, two door with a door opener on each. Motion light, porch light near door. 2 outlets and two lights. nothing big is used in garage, looking for standard garage advise. Wiring (old) is three different gauge sizes. Not going to use anything bigger then what out there now. The amp right now is 20 amp in the box.
Thank you
Tags
flyer1 garage
Electrical Wiring for Separate Garage HomeGuy2 Electrical 11 03-15-2013 10:50 PM
Installing 220 in garage for future welder - questions! wguttrid Electrical 7 01-31-2013 07:30 AM
Electrical loading question jimcorey Electrical 2 12-08-2012 07:27 AM
Electrical Outlet in my garage killed my garage door opener. thorxes Electrical 5 02-26-2012 03:17 AM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 12:40 AM
