Lost All Power And Breaker Not Tripped - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 02:48 PM   #16
Rewards Points: 590
I know the 2002 says to remove abandoned communications cable in plenums and ceilings. I don't think it applies to high voltage cabling.
operagost is offline   Reply With Quote
Old 02-24-2011, 03:40 PM   #17
Rewards Points: 712
Yes. There are many references to removing abandoned accessible cables in Chapters 7 and 8 of the NEC. That is a long way from removing ALL unused cables. I get tired of people posting hearsay code references. It's like a bad case of the old "telephone" game. One person tells another person tells another person and next thing you know, the code book is irrelevant. I suggest that any time someone tells you something is in the code, you ask for the reference (year and section).
Mark
busman is offline   Reply With Quote
Old 02-24-2011, 04:30 PM   #18
rditz's Avatar
Originally Posted by avro1 View Post
Well I just wanted to thank you all for your help. I think I found the problem joint but with some luck...
I guess I got lucky because I hate drywall work.
Avro,
you may want to go to HD or other big box store.. buy yourself a pencil tester.. it is a very useful, easy to use tool that will help you trace power problems. you touch it to a wire and the tip glows if it is energized, so tracing a wire is simple... you can touch each side of a connection and see if you have power on each.
glad you found your issue, I also would recommend that you plan a rainy day and replace all of the crimps and paper tape with wire-nuts and new tape.
rod
rditz is offline   Reply With Quote
Old 02-24-2011, 08:57 PM   #19
Rewards Points: 712
Originally Posted by rditz View Post
Avro,
rod
Good advice to replace bad splices, but why would you use tape with wire-nuts?
Mark
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Breaker tripped after power outage. What's up? Leah Frances Electrical 14 02-12-2009 07:56 PM
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
