Loss Power To My Outlets. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 09:44 PM   #1
Loss power To my Outlets.
Some how today I lost power only to all power outlets in my bathrooms.The lights all work just the outlets have stopped. I have a master bath with two outlets and downstairs bath with 1 outlet and a upstairs jack and jill bath with 2 outlets. Any suggestions to what I may need to do.
imfocused is offline   Reply With Quote
Old 07-17-2010, 09:54 PM   #2
Electrician
Proby's Avatar
A) Check the breaker box for a tripped breaker.
B) Check each receptacle, you might have one GFCI receptacle protecting every bathroom receptacle in the house. Check each one for a "Test" and "Reset" button. If you see those buttons, hit the "Reset" button (you might have to press it hard).
Proby is offline   Reply With Quote
Old 07-17-2010, 10:42 PM   #3
Thanks for the response man I have actual tried all those things and no power i will go to HD tomorrow and get a meter to test the outlets and wires.
Old 07-17-2010, 10:54 PM   #4
Electrician
Proby's Avatar
Some breakers are hard to tell when they are tripped. First I would "exercise" each breaker (this is good practice to do once a year) and switch them to the OFF position and then back ON. If that hasn't cleared the issue up I would go to the closest bathroom to the panel and pull out the receptacle and look for a loose wire. If you don't see a loose wire, this is where you need to test to see if you get voltage, but be careful because you will have live wires exposed when testing.
Old 07-17-2010, 11:03 PM   #5
ok will do Proby thanks! its just funny how it just started plus I have been noticing that my outlets in the house spark when I plug things in them. could this be the cause of my outlets losing power.
Old 07-17-2010, 11:19 PM   #6
Electrician
Proby's Avatar
That's odd. The only time you should expect an arc is when you unplug a high current drawing device (motor, heater, etc.) without shutting it off first.
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Electrical - Outlets with no power jogan Electrical 5 05-05-2009 02:06 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
ceiling light power loss pejay Electrical 4 08-22-2008 05:02 AM
Power to outlets but not enough? batesrt Electrical 5 02-04-2008 09:12 PM
