-   -   Loss power To my Outlets. (http://www.diychatroom.com/f18/loss-power-my-outlets-76471/)
imfocused 07-17-2010 10:44 PM
Some how today I lost power only to all power outlets in my bathrooms.The lights all work just the outlets have stopped. I have a master bath with two outlets and downstairs bath with 1 outlet and a upstairs jack and jill bath with 2 outlets. Any suggestions to what I may need to do.
Proby 07-17-2010 10:54 PM
A) Check the breaker box for a tripped breaker.
B) Check each receptacle, you might have one GFCI receptacle protecting every bathroom receptacle in the house. Check each one for a "Test" and "Reset" button. If you see those buttons, hit the "Reset" button (you might have to press it hard).
imfocused 07-17-2010 11:42 PM
Thanks for the response man I have actual tried all those things and no power i will go to HD tomorrow and get a meter to test the outlets and wires.
Proby 07-17-2010 11:54 PM
Some breakers are hard to tell when they are tripped. First I would "exercise" each breaker (this is good practice to do once a year) and switch them to the OFF position and then back ON. If that hasn't cleared the issue up I would go to the closest bathroom to the panel and pull out the receptacle and look for a loose wire. If you don't see a loose wire, this is where you need to test to see if you get voltage, but be careful because you will have live wires exposed when testing.
imfocused 07-18-2010 12:03 AM
ok will do Proby thanks! its just funny how it just started plus I have been noticing that my outlets in the house spark when I plug things in them. could this be the cause of my outlets losing power.
Proby 07-18-2010 12:19 AM
That's odd. The only time you should expect an arc is when you unplug a high current drawing device (motor, heater, etc.) without shutting it off first.
