Loose Romex Entering EMT Conduit Inside Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 03:48 PM   #1
Rewards Points: 1,062
Question
loose Romex entering EMT conduit inside ceiling
i am setting a switch on a plaster wall and will have EMT conduit running from the ceiling to the box. i was wondering how to make the transition between the loose Romex and EMT inside the ceiling, i.e. whether the wire can just enter the cut-off conduit pipe or it needs to have some sort of a terminal/fitting at the end of the pipe as to perhaps prevent the jagged edges from cutting into the cable and such. also does the cable coming in and out of the conduit and into the box need some sort of tightening at the connector (the regular connector doesn't seem to be tightening the cable, only the conduit to the connector).
thanks.
Old 11-02-2011, 04:32 PM   #2
Licensed electrician
Rewards Points: 1,258
You need a bushing at the top of the conduit. See the graphic from Mike Holt.
amakarevic (11-02-2011)
Old 11-02-2011, 07:57 PM   #3
Code05's Avatar
Rewards Points: 1,104
They also make these:
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Old 11-02-2011, 08:07 PM   #4
Electrical Contractor
kbsparky's Avatar
Or, you could just use the bushing shown in your graphic:
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 11-02-2011, 08:56 PM   #5
I like Code05's fitting. Looks perfect for what I need. But they didn't have it at Lowes.
Old 11-02-2011, 09:45 PM   #6
Code05's Avatar
Any supply house will have them. It is a EMT to NM/Romex adapter.
Old 11-02-2011, 10:32 PM   #7
Do not strip the sheath off of the NM going into the conduit sleeve.
THHN loose wire thru buried conduit? amakarevic Electrical 21 03-18-2011 01:48 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Tighten Loose Nowel Post On Inside Staircase csh49 Carpentry 3 03-12-2010 05:55 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
