Loose Ground Wire Exposed (not In Conduit) - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 05:04 PM   #1
Rewards Points: 1,062
loose ground wire exposed (not in conduit)
I was wondering if individual ground wire can be run inside the house but be exposed, i.e. not in conduit, if it has insulation. E.g. from a cable/phone box to the panel or from a su panel in a detached garage to the grounding rod.
I am asking this because i know loose wire must be in conduit but was unsure how it applies for ground only.
Old 08-26-2012, 11:07 AM   #2
Rewards Points: 58
Your question is ambiguous. Please ask it so we understand what you want to do or accomplish. This is why no one has responded to your thread.
Old 08-26-2012, 11:44 AM   #3
Master Electrician
Rewards Points: 3,678
Grounding electrode conductors are generally not installed in conduit, insulated or bare.
brric is online now   Reply With Quote
Old 08-26-2012, 11:47 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you are talking about running a single insulated ground wire to existing recepts, no, you cannot. They must be protected from physical damage.
The Following User Says Thank You to k_buz For This Useful Post:
amakarevic (08-26-2012)
Old 08-26-2012, 02:58 PM   #5
yes, that is what i was talking about. i have cca 80 ft from the cable and phone entry points to the main panel and running conduit will just be a nightmare. i was hoping to run just loose wire with green insulation
Old 08-26-2012, 03:02 PM   #6
the reason i thought loose wire MAY BE OK is because the cable dude use loose wire to ground the cable line to a cold water pipe and that was even outside, so even more exposed to damage. therefore, i thought that running it loose inside behind the wall, which is certainly more sheltered from damage, would be fine.
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
voltage on ground wire - multiple ground problem? Thaiman Electrical 14 04-02-2011 12:49 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 06:25 AM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 01:42 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
