Loose Electical Boxes - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-01-2013, 12:44 PM   #16
MarginallyQualified
Rewards Points: 2,464
Originally Posted by agoodboy View Post
...but is it a code violation to (secure the box with a couple of screws) like that? Just askin!
It's no more of a code violation than the madison straps...
and far less likely to ever be a shocking issue.
Old 08-01-2013, 08:18 PM   #17
Oh sure. But what I was asking if anyone knew if the NEC had anything to say about boring through the sides of approved boxes to add new fasteners.
agoodboy is offline   Reply With Quote
Old 08-01-2013, 08:38 PM   #18
MarginallyQualified
The NEC will refer to the UL listing which doesn't have any approved means to secure a box aside from what it had with/on it when the lab tested the design.
When UL wants a box to have nails or screws running through it...
Old 08-01-2013, 08:50 PM   #19
I think I understand then, the implication being “it is not a good idea to add your own new holes in the box”?
Old 08-01-2013, 09:42 PM   #20
MarginallyQualified
unless you have a loose box and don't want to do any drywall work
The Following User Says Thank You to TarheelTerp For This Useful Post:
MTN REMODEL LLC (08-01-2013)
Old 08-01-2013, 10:31 PM   #21
lol Yes! But you forgot to add " and you don't care what the NEC says" lol
Old 08-01-2013, 10:42 PM   #22
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,538
OK Guys.... Just trying to stir something up.... but to our code experts... what if you ran a grounding clip to that F clip????
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 08-02-2013, 07:59 AM   #23
Rewards Points: 6,652
Best
You could, but it will be hard to do, since they are malleable tin. You would have to find a fitting that would fit over the one clip, then you are taking away space from the side of the box. So again you are really not fixing anything.
Old 08-02-2013, 07:04 PM   #24
Brian58Fraga's Avatar
I would run screws through the side myself, but you could de-energize the circuit and cut out the box careful not to damage wire. Then add a deep cut in box
Brian58Fraga is offline   Reply With Quote
Old 08-02-2013, 10:14 PM   #25
Originally Posted by gregzoll View Post
As for the plastic boxes getting pulled out through the opening, there is more at hand, then just a lose box in the wall. Hack job comes to mind. Those boxes are rated for a certain amount of shear force, before they are able to be yanked off the nails or screws holding them to the wood stud.
Was wondering why no one responded to that. Couldn't that explain it. Would it be better to just cut out the old box and put in an old work box that would grab the wall nice and tight. Just a thought from a newbie.
whoops - just read the previous post. sorry about that.
Ceiling Boxes a7ecorsair Electrical 3 10-28-2010 09:19 PM
Outlet boxes extend beyond drywall JPFdiy Electrical 12 05-17-2010 09:09 AM
Sealing new boxes on an exterior wall Mthrboard Electrical 1 08-16-2009 08:05 PM
Building Planter Boxes kimberland30 Landscaping & Lawn Care 1 05-15-2009 10:19 PM
Ancient light boxes, how to remove Local Yokel Electrical 17 03-22-2009 04:32 PM
