Loose Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2008, 10:16 AM   #1
loose circuit breaker
my 15amp circuit breaker is loose,vibration is causing to lose power on the circuit,the breaker doesn't trip.should i tighten or just replace the breaker?
justorr is offline   Reply With Quote
Old 11-27-2008, 10:20 AM   #2
Electrical Contractor
kbsparky's Avatar
Is the breaker loose on the bus bar of the panel? Or is the bus bar corroded or pitted?
If you have an old worn out breaker, replacing it may be the answer.
If your panel has corroded or pitted bus bars, then a new breaker is only flushing good money after bad. You'll have to replace the panel in that case.
Old 11-27-2008, 11:31 AM   #3
With no upstream breakers of fuses, or maybe even with, there is an arc flash danger.
Old 11-27-2008, 11:48 AM   #4
What brand do you have?
When you take the breaker out (WHEN ITS OFF!) Is the bus burnt, corroded, pitted, etc?
Is the breaker warped as if it was hot?
rgsgww is offline   Reply With Quote
Old 11-28-2008, 11:06 AM   #5
Rewards Points: 204
Tighten? Are you saying the breaker is bolted in? If it is tighten it. Power off main breaker first.
Old 11-28-2008, 03:14 PM   #6
Some breakers have a screw that connects it to the pole bus! Other have a press connector.
Possibly, the screw wasn't tightened properly when it was installed. or it wasn't pressed into place properly.
As it was loose, damage may have occured where the breaker contacts the bus.
If you cannot tighten the mounting screw, you may be able to relocate the breaker to a spare position.
If you have no spare positions, try a new breaker.
REMEMBER TO TURN OFF THE MAINS BEFORE WORKING IN THE PANEL!
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 04:40 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
