Loose 20 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2009, 06:38 PM   #1
I replaced the 4 transformers in my flourescents. 4 @ 2 96"T12 each. All the lights worked great. Later on the circuit was blown. I tried to reset and nothing. It's a workshop with a 100 amp Homeline panel. I replaced the 20 amp breaker with a new Square D. It is very loose on the breaker bar, it only stays on with the cover on. The circuit will not come back on. Is there a different breaker for the Homeline box or is the breaker bar toast? Thanks.
aggiesrok is offline   Reply With Quote
Old 05-07-2009, 06:39 PM   #2
Licensed Pro
Make sure you have a Homeline breaker and that it is fully seated on the bus bar. Sometimes it takes a little effort to fully seat them. They should NOT be loose.
Old 05-07-2009, 06:41 PM   #3
Yup - 2 different breaker models
Square D
Square D - Homeline
Old 05-07-2009, 06:44 PM   #4
So the clip is different? Does the Homeline product have Square D on it?
Old 05-07-2009, 08:14 PM   #5
The ones in my subpanel have the Square D logo and HOM printed next to it.
surrogate is offline   Reply With Quote
Old 05-08-2009, 12:30 PM   #6
Rewards Points: 82
You need one exactly like the one you pictured. You may have a QO instead of a HOM breaker.
Square D makes more than one type.
Old 05-08-2009, 12:57 PM   #7
Licensed Pro
Both say Square D, clip and method of attachment are completely different.
Old 05-08-2009, 01:42 PM   #8
electrician
the easiest way for you to tell right now is look at the breaker, does it have a tripped preaker indicating window, if it does it's a load center breaker, if it doesn't it's a homeline.
Silk is offline   Reply With Quote
Old 05-08-2009, 01:56 PM   #9
Wouldn't it be pretty obvious if he has a QO breaker instead of the Homeline that he needs? The QO series are 3/4 inch tall, and the Homeline series are 1 inch tall.
thegonagle is offline   Reply With Quote
Old 05-08-2009, 01:57 PM   #10
Licensed Pro
Well it should be, but you never know...
Old 05-08-2009, 03:50 PM   #11
DIYer
Aren't Homeline breakers known for being very loose anyway?
I mean nothing holds them in except for the blade of the bus, right? It's not like QO where you have the clip.
Gigs is offline   Reply With Quote
Old 05-08-2009, 04:06 PM   #12
Yes it was a QO breaker and I obviously needed a Homeline. But the one I replaced was a QO and should not have been there to begin with. I put in the new Homeline and it is snug with no problems. Thanks again for all of the responses and help.
Old 05-09-2009, 06:42 AM   #13
Originally Posted by HouseHelper View Post
...but you never know...
Hmm... I think I just tasted my foot...
In any case, to the OP, thank you for the update. I'm glad it's fixed, and better than ever.
Tags
20amp , breaker , homeline , squared
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
loose circuit breaker justorr Electrical 5 11-28-2008 04:14 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
