Is Loomex The Same Thing As Romex? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2013, 12:36 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Is loomex the same thing as romex?
I always assumed so, but I just want to make sure...
Bought a tub of staples meant for Loomex, and the wires seem kinda loose in them, and I'm starting to wonder if this is the wrong product for the job. The box states it's good for 14/2 all the way to 12/3. If I put two 14/2 wires it's nice and snug but otherwise it's very loose unless I bash it in past the stops which it states not to do so I don't do it.
The issue with the wires being loose is as they move around the edges of the staples start to cut into the wire. I have not had any serious damage to the sheet due to this, but it just does not seem right.
Old 12-04-2013, 07:27 AM   #2
joed's Avatar
Rewards Points: 13,332
NM cable should be loose under staples. If it is tight then you have the wrong staple or pounded it in too far.
The Following 3 Users Say Thank You to joed For This Useful Post:
gregzoll (12-04-2013), Jim Port (12-04-2013), Philly Master (12-04-2013)
Old 12-04-2013, 01:18 PM   #3
Wire Chewer
Rewards Points: 132
Oh really? I always thought the whole idea was that it should be tight so the cable can't move around (and scratch against stuff). So these are correct then. Good to know.
Old 12-04-2013, 01:43 PM   #4
Rewards Points: 6,652
Just snug enough, to keep it from moving. You just do not want it against, so it leaves an imprint in the jacket.
Old 12-04-2013, 02:41 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
After my electrical rough-in I went around and removed all the staples in my house....
That way I can pull the wires out if I need to replace them.
Old 12-04-2013, 03:07 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
I hope you are yanking us.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-04-2013, 03:12 PM   #7
A "Handy Husband"
rjniles's Avatar
Loomex is a specific brand (Canadian company) of NM (Non Metallic)cable. Romex is also a brand name that has become synonymous with NM cable just as Kleenex has come to be any brand of tissue.
The Following User Says Thank You to rjniles For This Useful Post:
Old 12-04-2013, 03:38 PM   #8
JOATMON
ddawg16's Avatar
Who? Me? I would 'never' do something like that.
(Yea...I'm joking)
Old 12-04-2013, 09:09 PM   #9
Rewards Points: 986
Just for fun I hammered a wire staple in so it was level with the stud, and then took it all apart. There was no real damage to either the wire or the insulation.
I don't recommend it, but apparently you can do really abuse them. (I have however switch to the plastic staples with nails)
Toller is offline   Reply With Quote
Old 12-04-2013, 09:11 PM   #10
Wire Chewer
Rewards Points: 132
Actually sounds like a plan. For old work can also just shove romex under the baseboards and surface mount outlets. Lamp cord wire works great too as you can stuff more, maybe 2 or even 3 if you really push it in with the flat screw driver.
(kidding)
Replaceing Old, Brittle BX With Fresh Shiney Romex SeanRP Electrical 8 01-06-2011 03:11 PM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
Is metallic ceiling box OK for Romex? Ultrarunner2017 Electrical 6 12-04-2009 12:03 PM
How to maintain clearance between romex and duct in joist bay? TomServo Electrical 8 10-24-2009 02:31 PM
Exposed Romex Questions bakerhouse Electrical 1 05-13-2008 11:15 AM
