Looking For "Wrongs" In My Siemens Load Center - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 09:33 PM   #31
Rewards Points: 214
Originally Posted by Minus08 View Post
Question though: would the handle ties prevent one of the breakers from tripping if it needed to if the one it was tied to did not trip?
That won't stop the breaker from tripping. It's a popular misconception that a breaker won't trip if the handle can't move. Even if you held the handle in the "on" position, it would still trip.
fa_f3_20 is offline   Reply With Quote
Old 01-11-2012, 10:47 PM   #32
" Euro " electrician
frenchelectrican's Avatar
They are designed to trip even with the handle stuck on postion or use the locking peice to prevent someone turn the breaker off which I have see it from time to time.
That one reason why I have to look at the breakers carefull to find one is actually tripped espcally with older one they are famous for that.
Merci,
Marc
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 11:28 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 10:56 AM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
Load Center dwayne Electrical 4 07-09-2006 01:02 PM
