Looking For Way To Run Wire Along Foundation - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 06:30 PM   #1
Rewards Points: 308
Looking for way to run wire along foundation
About 15 years ago, when we first got satellite, the installers ran a single cord down from the chimney and tucked under the bottom panel of vinyl siding, along the brick foundation. Well, that has gradually grown over the years, from the HD antenna also on the chimney to the speakers by the pool and patio. Obviously, this bundle of wires is becoming a problem, as it is pulling the vinyl away from the metal plate it's supposed to be attached to.
So, I am looking for a better solution. This is a span of about 8-10 feet that the wire is running along the foundation. Any practical solutions? Thanks!
smokey847 is offline   Reply With Quote
Old 06-24-2012, 07:02 PM   #2
Pure Genius
Rewards Points: 150
Ide probably just sleeve it in some pvc attached to your foundation
Dierte is offline   Reply With Quote
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
