Looking For This Wall Plate (coax/outlet Combo) Pic Inside - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 01:51 PM   #1
jelly's Avatar
Rewards Points: 330
Looking for this wall plate (coax/outlet combo) pic inside
I have a 3 gang box with two outlets and a coax for my tv.
Is this up to code?
I looked online without any luck, is there a website that would have these unique plates?
jelly is offline   Reply With Quote
Old 03-08-2008, 01:58 PM   #2
Licensed electrician
Rewards Points: 1,234
I hope you know that you need a divider between the power and low voltage side.
I found this one but it is not a 3 gang.
http://www.aifittings.com/whnew76.ht...NAL_Wall_Plate
Perhaps you could use one of these?
http://www.aifittings.com/whnew98.htm
Old 03-08-2008, 02:52 PM   #3
Electrician
If you have a divider, then get one of these from leviton
chris75 is offline   Reply With Quote
Old 03-08-2008, 05:15 PM   #4
jelly's Avatar
Rewards Points: 330
well no, i do not have a divider in there at the moment...
Old 03-08-2008, 05:17 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
One is absolutely required!
Old 03-08-2008, 06:33 PM   #6
When is fishing season?
CowboyAndy's Avatar
A divider can be picked up at almost any home improvment store.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-08-2008, 06:39 PM   #7
Of course you can choose to ignore the requirement for the divider if it doesn't fit into your plans and you know more than others. J/K.
The requirement of the Boxster and the large shop to ignore this is not needed.
Old 03-08-2008, 06:59 PM   #8
Don't forget the fat wad of mattress cash
Just pull the cable out and use a low voltage cut in ring next to the 3 gang box. You will be able to find a triple duplex cover.....I think.
Plan ahead next time
220/221 is offline   Reply With Quote
Old 03-08-2008, 09:52 PM   #9
Guys
Im not an expert, but it seems to me some are making this a big deal. I found this divider online for 69 cents. http://www.internet-security-inc.com...ucts_id=538762
I know lowes sells carlon brand so they probably sell it too.
It appears that you remove the face plate slide this in the slot and its done. Less than a minute of work.
Is this correct?
luweee is offline   Reply With Quote
Old 03-08-2008, 11:47 PM   #10
Union Electrician
goose134's Avatar
That should do it.
goose134 is offline   Reply With Quote
Old 03-09-2008, 02:27 PM   #11
jelly's Avatar
Rewards Points: 330
Thanks for the responses.
Best thing I learned today.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 10:16 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
