Looking Tp Put A 240v Outlet In Garage. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 03:36 PM   #31
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Originally Posted by jsnone1 View Post
Sweet! So then I can just run some 12awg from the 30amp 240volt breaker directly to my Voltec unit then, correct? (I will most likely run it in conduit up the wall, across the ceiling, and down the other wall)
Normally you will need #10 wiring for a 30 amp circuit.
Edit:
Looked up the specs for that unit:
208/240 VAC 15 amp (20 amp circuit) 2 wire with ground
Use a 20 amp 2 pole breaker, not a 30 amp breaker and you can use #12 wire or cable
https://homecharging.spx.com/volt/pdf/GM10-463A.pdf
Coastal South Carolina
Old 10-09-2012, 03:54 PM   #32
Awesome, thanks! Added this forum to my favorites!!!
Edit:
jsnone1 is offline   Reply With Quote
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Strange 240v outlet BearcatBengal Electrical 30 03-02-2010 11:10 PM
240v 3 prong outlet ISSUES!! JanosX Electrical 4 12-05-2009 01:00 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 10:32 PM
