Looking Tp Put A 240v Outlet In Garage. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 11:06 AM   #16
Rewards Points: 324
Originally Posted by andrew79 View Post
You can't put 240v loads on slimline breakers. The slimlines are drawing 120v from the same leg of the service. The only way to hook up 240v loads is to use full size breakers. So you move some 120v loads to the slimline spacesavers or whatever you want to call them. Then remove the 15a breakers that you just took the wires off and replace them with a two pole 30a breaker.
yes you can.slimlines have two configurations.with handel ties 240,they have a rejection tab on the bottom also.if panel will take slims it will work.
oleguy74 is offline   Reply With Quote
Old 08-19-2012, 01:18 PM   #17
Master Electrician
Outs always hit the same leg. that would explain why I'm always wonderinging what your talking about with the space alottment. Any spacesavers I've ever installed will fit anywhere in the panel here as they have the same base as a regular breaker.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-19-2012, 03:08 PM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
2 pole GE slim (trim, tandem, half size or whatever you call them) with a handle tie bridge across 2 breaker positions and pick up both legs of the panel and give 240 volts. There are also slim breakers without the handle tie that fill a 1" space and give 2 120 volt circuits from the same leg of the panel.
Coastal South Carolina
Old 10-09-2012, 02:51 PM   #19
Could I do the same thing, remove the bottom left FOUR 15amp breakers, put in four slim breakers where the "hall bath light" and "smoke detectors" breakers were and move all the wiring for the to those four slim breakers. Then put a 30amp breaker where the "Loft Lights" and "masterbed lights" breakers were at???
Originally Posted by rjniles View Post
Your directory shows slots 17,18,19,20 will accept tandems. Remove the 2 full size 15 amp breakers in slots 18 & 20. Install a 30 amp 2 pole tandem in slots 18B and 20A.
Instal 2 single pole 15 amp tandems in slots 18A and 20B to replace the 2 15 amp full size you removed.
Or install a sub panel as others have suggested.
jsnone1 is offline   Reply With Quote
Old 10-09-2012, 03:28 PM   #20
A "Handy Husband"
rjniles's Avatar
Yep,use 2 of these for the 4 15 amp circuits:
http://www.homedepot.com/catalog/pro...eb5baa_300.jpg
And a regular 2 pole BR type 30 amp breaker.
A question: what are you using the 2 pole 30 amp for?
Old 10-09-2012, 03:30 PM   #21
A Voltec electric car charger.... Am I good?
Old 10-09-2012, 03:34 PM   #22
Rewards Points: 258
UMMM UMMM did you not read the thread????????
redman88 is offline   Reply With Quote
Old 10-09-2012, 03:35 PM   #23
Yes...
Take it I missed something
Old 10-09-2012, 03:38 PM   #24
Rewards Points: 258
Originally Posted by jsnone1 View Post
Yes...
Not directed at you but you did miss the mark as well, unless i read the thread wrong..... that is posible.
Old 10-09-2012, 03:38 PM   #25
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Depends on the model of panel.
Some will not accept mini breakers.
Old 10-09-2012, 03:41 PM   #26
A "Handy Husband"
rjniles's Avatar
This was not the ordinal poster that wanted the welder circuit.
Old 10-09-2012, 03:43 PM   #27
A "Handy Husband"
rjniles's Avatar
The panel label showed that it accepted BD type breakers (CH's BR panel tandems)
Old 10-09-2012, 03:44 PM   #28
So I good to go then?
Old 10-09-2012, 04:22 PM   #29
A "Handy Husband"
rjniles's Avatar
Old 10-09-2012, 04:27 PM   #30
Sweet! So then I can just run some 12awg from the 30amp 240volt breaker directly to my Voltec unit then, correct? (I will most likely run it in conduit up the wall, across the ceiling, and down the other wall)
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Strange 240v outlet BearcatBengal Electrical 30 03-03-2010 12:10 AM
240v 3 prong outlet ISSUES!! JanosX Electrical 4 12-05-2009 02:00 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 11:32 PM
