Looking For Techniques For An Alternative To Landscape Lighting Connectors - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 05:32 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Dornier View Post
Have you used the ACE connectors that work with multiple wires?
I need to connect fixtures to the line in addition to a few splices.
Just wondering how the shrink tubing would work with a light's wire bending off to the side.
What I do is twist two wires plus the fixture wire together and insert it in one end under both screws, I allow the heat shrink to extend beyond the terminal device, then I crimp it shut after it has shrunk...
You wont fit more than two #12's and a fixture lead in that size ace connector, but you can buy larger ones if needed.
Old 10-08-2012, 07:34 PM   #17
dmxtothemax's Avatar
Rewards Points: 5,360
Have you considered automotive style crimp on connectors ?
Cheap readily available and work great !
And can easily heatshrinked if underground use.
dmxtothemax is online now   Reply With Quote
Old 10-08-2012, 07:52 PM   #18
E2 Electrician
Attachment 58552
Attachment 58553
No way would I use those..
Old 10-08-2012, 07:58 PM   #19
Rewards Points: 117
I can't see those connectors on the depot site. Are they expensive?
Dornier is offline   Reply With Quote
Old 10-08-2012, 10:34 PM   #20
You should be able to get them in the automotive suppliers !
They are used in car wiring.
They are not usually used in home DIY.
Old 10-08-2012, 10:40 PM   #21
Rewards Points: 117
No I meant the ACE connectors.
Old 10-08-2012, 10:46 PM   #22
Why ?
I have used them many times,
even in high current situations they work well.
I have used them in mains applications,
240v at 10a, No problems.
So landscapping would work also.
The only problem would be if they dont meet code !
Solar Landscape Lighting - Any generate REAL light? 99altrade Landscaping & Lawn Care 4 08-02-2011 12:15 PM
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 06:37 AM
Low voltage landscape lighting rjniles Landscaping & Lawn Care 2 09-24-2010 09:55 AM
DIY low-voltage landscape lighting?? kooshball Electrical 1 03-23-2010 05:36 PM
Help me pick out landscape lighting vanamc Landscaping & Lawn Care 3 05-04-2009 08:49 PM
