Old 10-07-2012, 09:19 AM   #1
Looking for techniques for an alternative to landscape lighting connectors
I am replacing some old wiring from the previous owners landscape lights.
Does anyone have any suggestions for DIY connectors for the lights and cable splitters?
The ones I have tried aren't really that great and the price is too high for what I got.
Shrink tubing, wire nuts, et al?
Just trying to keep from spending if I don't have too.
Thanks.
Dornier is offline   Reply With Quote
Old 10-07-2012, 11:25 AM   #2
JOATMON
ddawg16's Avatar
Well....it's low voltage so you can pretty much use what you want.
Do you have any splices that will be in the ground? As in....wire was too short so you had to extend it?
It at all possible, avoid splices.....the wire is pretty cheap.....if possible run a new wire from inside the light to the transformer....at the transformer....wire nuts are fine because the transformer should be in a dry protected area.
If you 'have' to put in a splice in the ground....I would solder and use heat shrink to seal it.....actually...heat shrink over the individual wires and then a larger one over the whole splice.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 10-07-2012, 12:38 PM   #3
Thanks.
No splices at at all so far.
I had been thinking since I posted; shrink tubing over soldered, then taped, might be better than involving a nut in some way.
Old 10-07-2012, 12:45 PM   #4
Soldering makes the best connections. But you can use wire nuts as an alternative, in place of connectors that came with the kit and that you feel are too flimsy.
Do it yourself splices must not be buried. You need a box to enclose the splices, a waterproof box if undeground. The cover has to be accessible.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 10-07-2012, 01:20 PM   #5
E2 Electrician
stickboy1375's Avatar
This is the only way to splice low voltage wires that will pass the test of time in my opinion.
Old 10-07-2012, 01:27 PM   #6
That's a hex nut to tighten played together?
Old 10-07-2012, 01:28 PM   #7
Is that something you made?
Old 10-07-2012, 01:29 PM   #8
Never mind, I see the link now. Tubing over that?
Old 10-07-2012, 07:31 PM   #9
E2 Electrician
Its called an ACE connector, and it gets heat shrinked, moisture is evil.
Old 10-07-2012, 07:39 PM   #10
Stickboy,
where can i get these connectors? the link wasn't on my page
Mule98 is offline   Reply With Quote
Old 10-07-2012, 07:45 PM   #11
E2 Electrician
Originally Posted by Mule98 View Post
Stickboy,
Just google 'Ace Connector'
The Following User Says Thank You to stickboy1375 For This Useful Post:
Mule98 (10-07-2012)
Old 10-07-2012, 07:50 PM   #12
Does that ACE connector work on splices? I just realized I'll need to in order to branch of down two ends of a flower bed.
Old 10-07-2012, 07:52 PM   #13
E2 Electrician
Um, its made for splices, I dont understand your question?
Old 10-07-2012, 07:58 PM   #14
Ok. I was reading the page while walkin through an airport.
Made for splices. Made to be buried.
Got it.
Thanks.
Old 10-08-2012, 05:56 PM   #15
Have you used the ACE connectors that work with multiple wires?
I need to connect fixtures to the line in addition to a few splices.
Just wondering how the shrink tubing would work with a light's wire bending off to the side.
Solar Landscape Lighting - Any generate REAL light? 99altrade Landscaping & Lawn Care 4 08-02-2011 01:15 PM
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 07:37 AM
Low voltage landscape lighting rjniles Landscaping & Lawn Care 2 09-24-2010 10:55 AM
DIY low-voltage landscape lighting?? kooshball Electrical 1 03-23-2010 06:36 PM
Help me pick out landscape lighting vanamc Landscaping & Lawn Care 3 05-04-2009 09:49 PM
