Looking For Some Assistance. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 09:29 AM   #1
Looking for some assistance.
I'm trying to figure out how to get power to a shop that I have built, so I came here looking for some help/guidance. I will try to give you guys as much info as I can. My setup currently consist of a 400amp transformer on the pole, running down into a 200amp panel also on the pole. Then ran underground about 60 feet to my house, where there is another 200 amp panel in my utility room. My main question is it possible to run another 100 amp subpanel to my shop through the panel that is out on my utility pole? Or is my only option to have another meter loop installed with a separate 200amp panel? Let me know if I need to give more info to help get my question answered. Thanks in advance. -Matt
here is a pic of how the panel is setup on the utility pole.
DarkHorse is offline   Reply With Quote
Old 09-02-2011, 09:35 AM   #2
Rewards Points: 6,652
You may have to have another meter installed, just depends on your utility, since everyone of them are different. If going from house to shop, I would be concerned with voltage drop, depending on what machinery or tools you will be using out there. I take it that the first 200 amp panel, is just the main disconnect, with the meter in it.
Old 09-02-2011, 10:01 AM   #3
I would like to get power directly from the pole outside, and not deal with the house wiring at all. But i'm thinking that I need to pull too many amps to be able to use my existing 200amp service. I have a small powder coating business, and my oven needs about 50amps alone, combine that with my 5hp air compressor, dust collector system, lights, and misc. shop tools, not looking too good. My shop is about 100ft from the main utility pole.
Old 09-02-2011, 10:57 AM   #4
If it was me, I would go from the transformer to the shop also. That is just my thought on your set up. Only drawback is, that you will need a meter at the shop also.
Old 09-02-2011, 11:40 AM   #5
Last year I was in the same boat as you. I built a detached garage and had the option of tieing from the house service back to the detached, or run a seperate service from the outsie padmount transformer directly to the new detached garage. We went with the new service directly to the detached.
Id recommend the same idea. If youre running a business it makes keeping your utility records a lot easier if theres seperate bills. You will have to pay an extra meter charge, but aside from that, its better to keep the two systems seperate. Another benefit of seperate is that if you blow the business power, your house keeps going, and vice versa.
I think you should call up your local utility and have them give you options for a seperate service from the padmount (outside transformer) to your shop, or from your house. Other then saving the cost of an additional meter charge, which isnt much, I cant think of any benefit of having it tied back to your house power.
Wiscbldr is offline   Reply With Quote
Old 09-02-2011, 03:38 PM   #6
Electrical Contractor
kbsparky's Avatar
You have what is commonly called a "feed-through" panel out on the pole. There are 8 spaces for future circuits provided.
Simply install a 100 Amp plug-in breaker into that panel, and run your line to the shop from there.
No need for any additional meter, etc. You already have everything you need in place.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Speedy Petey (09-02-2011)
Old 09-02-2011, 05:22 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Agree. You have the perfect setup to do exactly what you propose.
Michigan contractors I need some assistance hvaclover HVAC 3 03-31-2011 07:34 PM
A little assistance? FortyNinerFan Painting 12 03-25-2011 06:46 PM
Need assistance determining header specifications rgb71 Building & Construction 1 01-06-2011 05:38 PM
Need assistance installing brazilian cherry stairway BobS0327 Carpentry 8 09-07-2010 10:30 AM
Getting Contractor Assistance, Doing Work Myself Sean Building & Construction 4 12-27-2006 06:13 AM
