Looking For A Push Button For Garbage Disposal - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 01:43 PM   #16
That's just a regular switch. I'm looking for a small push button or something similar to mount to the front of the sink cabinet.
docmattman is offline   Reply With Quote
Old 02-16-2011, 01:44 PM   #17
fabrk8r
fabrk8r's Avatar
Or, if you don't want to drive...http://cgi.ebay.com/P-S-LEGRAND-15-A...item564279f889
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-16-2011, 01:47 PM   #18
This one looks like it could do the trick:
http://www.drillspot.com/products/54...ry_push_switch
Old 02-16-2011, 01:48 PM   #19
fabrk8r
fabrk8r's Avatar
These are NOT light switches...these are momentary...only closed when pressure is applied...strictly for garbage disposals.
Old 02-16-2011, 01:50 PM   #20
Actually this one might be better:
http://www.drillspot.com/products/44...70_Push_Switch
The other one has a warning that it can cause cancer and birth defects!?!?!
Old 02-16-2011, 01:51 PM   #21
I'm not looking for a light switch. I want this for my garbage disposal.
Old 02-16-2011, 01:53 PM   #22
fabrk8r
fabrk8r's Avatar
I give up.
Well, like I said earlier, McMaster-Carr is where I buy stuff like what you are wanting...cheap and quick.
Old 02-16-2011, 02:02 PM   #23
Rewards Points: 150
Don't be pushing on that metal switch with wet hands.
240sx4u is offline   Reply With Quote
Old 02-16-2011, 02:04 PM   #24
fabrk8r
fabrk8r's Avatar
Please don't consider using a NON-MOMENTARY switch for a disposal either...metal or not.
Bye now...I'm going to go reinvent the wheel.
Old 02-16-2011, 02:09 PM   #25
Why not? I don't need a full sized light switch. I'm looking for something small to mount in the cabinet under the counter top. I don't want a full light switch box in there.
Old 02-16-2011, 02:13 PM   #26
Rewards Points: 150
You aren't making this easy and it's becoming comical.
A non momentary switch is a switch that locks in the on position until you turn it back off. A momentary switch only stays engaged while you are pressing it.
You will need an enclosed box with all your connections to be code compliant I am sure.
What you should be looking for is a waterproof momentary pushbutton switch.
Old 02-16-2011, 02:16 PM   #27
Rewards Points: 150
Unless this is going to be hidden totally inside the cabinet where you have to open the door to access it, I think it's an awful idea. Little kids love to push buttons.
Old 02-16-2011, 02:52 PM   #28
Rewards Points: 558
Are you looking for something like this?
You can find it here: http://www.needplumbingsupplies.com/In-Sink-Erator-Garbage-Disposers.asp?id=7318&NpsRfrSrc=Shopping&NpsRfrMfg =5
epson is offline   Reply With Quote
Old 02-16-2011, 02:56 PM   #29
Originally Posted by 240sx4u View Post
... I think it's an awful idea. Little kids love to push buttons.
I agree. BAD idea from the onset. They are usually put on the wall above the countertop for good reason. Besides kids, I'll bet you'll turn it on by accident just by bumping into it while near the sink.
Willis
williswires is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 11:39 AM
Push Button Switch for Electric Motor crmays Electrical 2 02-06-2010 06:29 PM
Push Button switches & dimmers ? cellophane Electrical 2 12-10-2009 06:49 PM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 11:36 AM
