Old 01-15-2013, 10:52 AM   #1
Looking for more capacity
Hello spark enthusiasts!
I am living in a 30 y.o. home that I purchased last year and would like to get a few more breakers installed. I would like to run the computers in my office off their own line, add an isolated line or two to the kitchen (everything currently on the same circuit) and a few other places in the house.
Also, there are a few beakers that have been double-tapped. That's probably not legal.
I think 6 more breakers are all I would needed. To be on the safe side, let's call it 8.
With the exception of a possible dehumidifier in the crawl space, I would not be adding much additional usage, just separating things out.
What would be need to be done to add this extra capacity?
Thanks!
MurphyMan is offline   Reply With Quote
Old 01-15-2013, 11:09 AM   #2
Doesnt look like you have the room to add more breakers. Maybe upgrade to a larger panel? Or use those double breakers that have two breakers in the space of one.
Come and see the progress on my mobile home paradise
TrailerParadise is offline   Reply With Quote
Old 01-15-2013, 11:10 AM   #3
Trucon01's Avatar
What type of service do you have coming in 200A, 100A? Do a search on here for Sub-Panels.
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 01-15-2013, 11:11 AM   #4
It already has several of those two breaker items.
Old 01-15-2013, 11:15 AM   #5
Sorry, I should have mentioned
Square D. 200A
Old 01-15-2013, 12:00 PM   #6
eastcoastsparky's Avatar
Sub panel
Sent from my iPhone using DIY Forum
eastcoastsparky is offline   Reply With Quote
The Following User Says Thank You to eastcoastsparky For This Useful Post:
MurphyMan (01-15-2013)
Old 01-15-2013, 12:09 PM   #7
I know the sub panel is the easiest way and would work fine but I'd like to just suggest you look into replacing the main panel for a larger one. It's really not that much more difficult and would look much cleaner.
Reasons: The current main panel is a small one and to add a sub you will loose 2 more slots on the main (to run to the sub). This would mean the sub would have to be a larger one. To run the current circuits to the sub there might be splicing involved in the panels anyway which is ok but you may get by with fewer or no splicing if you just replace the main.
That said, I'd look into replacing the main but if it turns out to be a headache then the sub will work for sure. Just remember to run the neutrals and grounds seperate in the sub panel.
Daltex is offline   Reply With Quote
The Following User Says Thank You to Daltex For This Useful Post:
Old 01-15-2013, 12:33 PM   #8
CodeEnforcer
HIVOLT's Avatar
Install a 200A 40 circuit main breaker panel.
HIVOLT is offline   Reply With Quote
The Following User Says Thank You to HIVOLT For This Useful Post:
Old 01-15-2013, 12:37 PM   #9
Replacing a main panel, even a small one, is usually more complicated than adding a subpanel, even a large one.
1. You may need a separate permit on top of the permit for adding more circuits in the house.
2. You may need to coordinate the installation with the power company since the feed from the meter has no shutoff or breaker (overcurrent protection) specifically for your house.
3. There are many more cables and wires that need to be unhooked, perhaps rerouted a tad, and hooked up again.
With a subpanel, only enough circuits need to be rerouted from the existing panel to free up breaker positions for the subpanel feed.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 01-15-2013, 12:42 PM   #10
Okay gents and ladies. I get the picture.
I think my preference would be to have a larger single panel, but on the other hand, the sub panel would probably be easier. I am in no rush, so I will spend some time cogitating on it.
Thanks for the advice. Plenty to chew on.
Murph
Old 01-15-2013, 12:46 PM   #11
If you are planning on flying under the radar, you gotta go sub-panel.
michaelcherr is offline   Reply With Quote
The Following 4 Users Say Thank You to michaelcherr For This Useful Post:
HIVOLT (01-15-2013), mpoulton (01-15-2013), MurphyMan (01-15-2013), Speedy Petey (01-15-2013)
Old 01-15-2013, 04:02 PM   #12
Lic Electrical Inspector
electures's Avatar
Or go for broke and install the 200A 60 circuit panel.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
NJMarine (01-15-2013)
Old 01-16-2013, 01:20 PM   #13
Special User
I thought residences were limited to 40 circuits per panel...
Anyhoo, your best best is to find out what model of panel bus you have, to see how many tandems it will accept. Some will only accept tandems in the bottom four slots. Others will accept tandems in all slots. If yours accepts them in all slots, just start adding tandems. In addition to regular "twin" tandems, you can also get 20-50-50-20 and 15-30-30-15 etc "quads" that let you supply a 240V load AND two additional 120V circuits using two slots.
If your existing panel will not accept tandems in all slots, you still probably don't have to change out the whole panel box -- just the panel guts. Label then disconnect all the wires, pull the breakers out, unscrew the black bus assembly from the back of the box, screw in a new bus assembly, reinstall breakers, reconnect wires. You'll need to know the part number of box you have now, so you can purchase a new "bigger" bus (either one with more slots, or one that accepts tandems in all slots) that is compatible with your existing box. Note that if you get a bus with more slots, you may also need to replace the panel front, as your existing front may not have enough knockouts to accommodate the lower breakers.
BTW many Square D breakers are rated for double-tapping. Look for clamp plates with a slot on each side of the screw -- if yours has those, you can double-tap.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-16-2013, 09:26 PM   #14
Not anymore. They eliminated that in the most recent NEC revision.
fa_f3_20 is offline   Reply With Quote
Maytag MAV7000AWW Washer capacity? staron Appliances 1 03-14-2012 11:10 PM
Box Capacity Question ARB Electrical 15 01-12-2012 09:23 AM
Box capacity question: DiegoJames Electrical 3 10-21-2011 10:18 PM
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 08:39 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
