Looking For Help In Testing Why Switched Outlet Is Always Hot - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2007, 04:58 PM   #1
Looking for help in testing why switched outlet is always hot
Hi, first off, I'm a total novice non-electrician-guy so bear with me as I am unfamiliar with most electrical lingo. Bought a place recently (built in '94) and switched out the outlets that were here - nothing big, just cosmetic stuff. I took special care to wire everything exactly the way that it was, just one-for-one switchouts. Now I've got a few outlets that were previously controlled by switches (top switched, bottom hot) but are now always hot - top and bottom. So, 2 questions: 1. Is there an easy way, or a tool that can help me to find out where the problem is - switch or outlet 2. Is having these outlets always hot a safety hazard? If there's no easy way to troubleshoot them (I definitely don't want to pay an electrician to come over and tackle something which I'm sure is probably a fairly simple issue), and if it's not a safety hazard, I'd just as soon leave them be and deal with the minor annoyance. Any help is much appreciated! Eric
geocrash is offline   Reply With Quote
Old 11-26-2007, 05:03 PM   #2
You have to snap out a little metal tab between the hot posts on the sides of those receptacles that are switched.
When you rewired new receptacles just as the old ones looked, you probably didn't notice that the connection between the two gold colored screws had been removed from the original receptacles.
NateHanson is offline   Reply With Quote
Old 11-26-2007, 05:06 PM   #3
wow - thanks for the quick reply! will try give it a shot and let you know!
Old 11-26-2007, 08:15 PM   #4
Nate, everything worked when I followed your suggestion, thanks so much again for the fast reply!
Eric
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Switched Outlet with humidistat. Clutchcargo Electrical 3 06-21-2007 06:20 PM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 01:07 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
