Looking For Good Digital Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2008, 07:54 PM   #1
looking for good digital thermostat
sorry if this post is in the wrong place.
looking for a good digital, programmable thermostat to retrofit into my house.
any suggestions for something under $100?
thanks!
wombosi is offline   Reply With Quote
Old 09-21-2008, 08:09 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Yeah, this should be posted in the HVAC section. A moderator will probably move it for you.
I've had good luck with White-Rogers, Lux, and Honeywell. Some Honeywell ones can be a pain to install though.
Look for one that works with your system (gas, elect, heat pump, etc.) with features you like.
Kyle
Old 09-21-2008, 09:07 PM   #3
Rewards Points: 1,574
Honeywell Vision-Pro series. Make sure you get right type for your system as was stated earlier. Most HVAC sites I've been to tell homeowners not to bother with most of the stuff available at the big box stores. I got mine off ebay (new in the box) for about $120, a Vision Pro and very satisfied with it.
bob22 is offline   Reply With Quote
Old 09-21-2008, 10:23 PM   #4
fix it
I've been using a RiteTemp 8030c digital touchscreen for almost 3 years that I got at the big Orange box and have had good luck with it. It was around $90 at the time. It is very configurable for the price. The only thing it's missing is a backlight, but they have newer models with them now. Honeywell seemed much more expensive for the same features and I didn't think it was worth it. Personally, I think you pay too much for that name.
detailedEye is offline   Reply With Quote
Old 09-22-2008, 07:47 PM   #5
Try this thread:
http://www.hvac-talk.com/vbb/showthr...ghlight=vision
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 HVAC 4 06-02-2008 04:44 PM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 12:52 PM
How to connect a Digital Thermostat jfgagnon Electrical 2 05-10-2007 01:01 PM
