Looking For Electrically Controlled Valve For Drinking Water - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 11:40 AM   #1
Author
unicornforge's Avatar
Looking for electrically controlled valve for drinking water
I am looking for a cold water valve that can be electrically controlled on a standard 120 AC circuit or DC batteries. Components would need to be intended for outside use. I would appreciate knowing the correct name/terminology for finding/ordering one, as well as suggestions on where I could find one.
I would like to be able to attach a motion sensor to control a water valve outside the house so that drinking water turns on when the sensor is approached by a dog. Currently the only available motion controlled drinking fountain available for sale has a reputation for not being dependable, so I would like to make my own DIY dependable dog watering fountain.
Thank you in advance for your assistance.
unicornforge is offline   Reply With Quote
Old 12-27-2012, 11:45 AM   #2
Rewards Points: 58
It is called a solenoid and can be purchased from any commercial/industrial supply house. Like Grainger. You order the solenoid with the coil voltage you want and the NPT pipe size you want to use. Very simple. Google "solenoid" and you will see.
Old 12-27-2012, 12:02 PM   #3
Author
I am having difficulty wading through the numerous search results for "solenoid", even when I limit the search to water/liquids. The various sellers assume that folks already know about the various types of solenoids and their usage and compatible valving and application details. Solenoids are in vehicles, pneumatic and just about anything else that has a electronic control.
Is there anything that I can read to understand what is in the search results for solenoids where the search result is limited to drinking water systems ? Especially what valving is compatible with each type of solenoid?
Sorry, but I can't decipher the descriptions of the items provided by vendors of solenoids for drinking water systems.
Old 12-27-2012, 01:27 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,864
Use a sprinkler valve. They are cheap and every home improvement store sells them. You'll need a 24VAC transformer to power it (also sold by the same stores for sprinkler systems).
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 12-27-2012, 01:29 PM   #5
Rewards Points: 744
and then wire in a passive infrared motion detector.
Seattle2k is offline   Reply With Quote
Old 12-27-2012, 02:12 PM   #6
Engineer
Rewards Points: 161
You might also try a floor pressure switch or switch mat vice a motion sensor to trigger the solenoid. When the dog steps on it it starts the flow of water.
diystephen is offline   Reply With Quote
Old 12-27-2012, 03:03 PM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
buy a cheap motion detector flood light take the motion detector part and wire it up to a 120v solenoid and make sure you have GFCI protection.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 12-27-2012, 10:02 PM   #8
The are a myriad of different solenoid controlled valves available. Plumbing supply shops will have them available.
eg. https://www.google.ca/search?q=solen...w=1440&bih=722
Old 12-27-2012, 10:30 PM   #9
dmxtothemax's Avatar
Rewards Points: 5,098
Go and visit an irrigation supply house.
There are many types of solinoid valves available,
Which one depends on pressure and what plumbing
fittings you want to use.
I am sure that if you explain it to them they will
advise you on what to use.
simplist is to use a motion sensor a suitable wall wart
and a suitable valve.
dmxtothemax is offline   Reply With Quote
Old 12-28-2012, 02:13 AM   #10
Oso954's Avatar
Rewards Points: 444
Go to a pet supply, buy a Lixit, and be done with it.
It is mechanical rather than electric, but it works well.
Oso954 is offline   Reply With Quote
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Sizing a dual shut off valve for a water line to fridge ericman Plumbing 10 08-19-2011 10:47 PM
Water valve will not shut off smcpherson Appliances 2 05-18-2011 10:55 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Replacing Dishwasher - Water Valve Help? BCreed025 Plumbing 1 07-26-2010 05:01 PM
