Looking For A Cheap Fix - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 12:45 PM   #1
Looking for a cheap fix
I bought a portable car jumper and within the first 2 weeks of having it, the ac dc adapter fell out of the wall and the plastic casing on the adapter portion which plugs into the wall, broke.
I have priced replacing the ac dc adapter which at a minimum will cost me 30 dollars, or replacing the entire unit which will cost me about 80 dollars. I was planning on just using some electrical tape to cover up the opening, but I want to see if anyone else had some better ideas. Please see the attached picture and tell me what you think.
Obviously my concern is electric shock.
Sartrean is offline   Reply With Quote
Old 03-13-2012, 12:50 PM   #2
Rewards Points: 12,886
Some Duco model glue and glue the pieces back together.
Old 03-13-2012, 01:40 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You should also replace the receptacle that the transformer plugs into because it's probably lost it's ability to hold a plug because it's worn out.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-13-2012, 01:50 PM   #4
Sorry, I should've mentioned that I no longer have the plastic pieces
Old 03-13-2012, 01:56 PM   #5
goodwill
Hardway is offline   Reply With Quote
Old 03-13-2012, 02:26 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,864
There's no way a replacement cost's $30. What voltage and current is the adapter?
mpoulton is offline   Reply With Quote
Old 03-13-2012, 03:10 PM   #7
Any Radio Shack, yard sale, Flea market would have one of these. Just match the voltage on the lable.
Old 03-13-2012, 03:27 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 858
Hopefully you can tell the voltage and wattage of the unit....you should be able to get one off the internet for about $10-15.
Side note....I have no need for a porable car jumper....you should look at what is going wrong....all your doing is putting a bandaid on a problem that should be fixed......I don't even own jumper cables....though I do have a battery charger....mainly because I have a jeep that sits for long periods of time...
ddawg16 is online now   Reply With Quote
Old 03-13-2012, 03:30 PM   #9
rrolleston's Avatar
as long as you can get one with the same voltage and the correct plug it should work. My booster pack can use the same charging adapter as my generator. Usually they are just a 12v DC adapter.
Old 03-13-2012, 05:51 PM   #10
I went to radio shack, and gave them the mA and AC voltage that I needed. They were charging $29.99 cents.
Old 03-13-2012, 05:54 PM   #11
This battery jumper is more for preventive maintenance piece of equipment. We have 2 cars, 3 motorcycles, and 1 lawn mower. While this never happens to the cars, the motorcycles and lawn mower batteries take a hit in the winter season, and sometimes will not start the vehicle they are attached to. I do use a battery tender, but this device just allows us to get things going when we don't have time to do the charge.
Old 03-14-2012, 01:43 AM   #12
Radio Shack is the problem there. Use the Internet.
Old 03-14-2012, 01:58 AM   #13
rrolleston's Avatar
When I was a young kid radio shack was the best place to find all sorts of gadgets for home electrical projects at great prices. Seems like they have cut back and raised their prices.
Old 03-14-2012, 03:24 AM   #14
I would hit up a second hand store like mentioned above or something like that. All you need is the correct voltage. Cut and splice the barrel connector or what ever is on the other end to the new adapter and youre back in the game. On a side note, I also know some shadey characters that would just return the item and say it came out of the box that way and walk out with a brand new one.
Shane1 is offline   Reply With Quote
Old 03-14-2012, 03:44 AM   #15
Rewards Points: 1,192
I think you dropped it and are trying to get over.
bobelectric is offline   Reply With Quote
