Looking For A Book On Basic Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2008, 01:10 PM   #1
Lonicera's Avatar
Send a message via Yahoo to Lonicera
Looking for a book on basic wiring
I am building a 16x24 cabin. Can anyone suggest a book title that would allow me to do some of the grunt work, before I am at the stage where I need a licensed electrician?
Lonicera is offline   Reply With Quote
Old 04-04-2008, 01:22 PM   #2
When is fishing season?
CowboyAndy's Avatar
Chances are you are going to need a licensed electrician from the get go. Most will not approve of "grunt" work being done without then spelling out how they would like it.
However, you may be able to find one that would be willing to let you do some of the drilling, wire pulling, etc under their direction.
Remember, when a licensed electrician puts their name and license on a job, they are responsible for the job.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-04-2008, 03:11 PM   #3
Res Ipsa Loquitur
I would check and see what is required in your area. In my town I am allowed to do almost 100% of my electrical work ON MY OWN HOME. This would require permits and an electrical inspection but would not need any intervention by a licensed electrician.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 04-04-2008, 04:03 PM   #4
RippySkippy's Avatar
There are MANY books out there...the best thing for you to do is hit your local library. I started with a couple of basic books and quickly found that for our area (only residential wiring), there are many basic rules, but for me, since I don't wire daily, all I really ended up needing was the basic schematics for some switch wiring. If I can locate the name of the book I'll post it later.
One more thing...if you're in an area that needs to be inspected, you may want to call the inspector early on...and get a read on their personality type and ask what they like and expect along the way. It's way easier to have them on your side as you move the project along.
RippySkippy is offline   Reply With Quote
Old 04-04-2008, 06:10 PM   #5
CowboyAndy's Avatar
That is great advice. In my experience (which ain't much, but I have dealt with several different inspectors) no 2 are the same. Granted, they all follow the same code (barring any local adjustments) but they all have different personalities.
BTW, Wiring Simplified is a pretty decent book, as is HD's Wiring 1-2-3.
MY HOUSE OWNS ME!
Old 04-04-2008, 06:22 PM   #6
Licensed Pro
Wiring a House by Rex Cauldwell
Old 04-04-2008, 06:28 PM   #7
Rewards Points: 266
I would try and find books that were actually written by someone in the business (like "Wiring a House"), rather than one by a bunch of brainless editors. I have noticed a lot of errors made on the theory aspect of electricity in those books. (also code violations!) Sometimes even the pictures can be misleading.
junkcollector is offline   Reply With Quote
Old 04-04-2008, 06:46 PM   #8
Master Of Nothing
mr500's Avatar
I have had good luck with the book I bought at HD. Its put out by black and decker. It doesn't go into great detail with codes, but it does show a lot. I wired up my garage and workshop using it. AND of course help from this forum!!
Its really a good book IMO. great diagrams. You can flip through it before you guy it. HD all over the place sells it. Black and Decker complete Home Wiring.
Mike
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 04-08-2008, 11:39 AM   #9
Learning by Doing
Leah Frances's Avatar
Check out reviews of books about wiring.
FYI: reviews of electrical DIY books
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
need: "new construction" book on wiring bjherron Electrical 4 09-21-2007 03:23 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
