Looking For Bendable/Posable Small Wire Sheath - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 11:18 AM   #1
I'm working on a small electronics project which will run off a USB port on a laptop. Unfortunately, I haven't found the right type of housing yet. I'm looking for a bendable, posable shaft that is around 10mm in diameter that can be cut down and can possibly be bought in bulk. Additionally, since the wires I'm using are so thin, copper is probably not the best option. Any suggestions would be very much appreciated.
Thanks,
- MT
mTorbin is offline   Reply With Quote
Old 02-18-2011, 01:55 PM   #2
Search for the phrase flexible gooseneck tubing and you should find some results relevant to your needs.
Matsukaze is offline   Reply With Quote
Old 02-18-2011, 02:04 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I would look for 10mm round bar in either aluminum or stainless steel. Something such as that or similar should be available through most metal suppliers.
I don't know what or how you are using it so I don't know if either of those would fit your requirements or not.
Old 02-22-2011, 08:22 PM   #4
Sorry for the late response.
Matsukaze - That's exactly what I'm looking for. Unfortunately, it looks like it's either mostly wholesale or min. orders of 500.
@nap - I'm building a USB laptop light and I need something that is bendable.
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 03:15 PM
How to Strip the Sheath HooKooDooKu Electrical 17 01-27-2010 11:25 PM
Wire size for small outdoor shop?? Danielm Electrical 1 01-12-2010 05:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
