Look Of Electrical Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 05:35 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Originally Posted by stickboy1375 View Post
Pretty creative scenario, no?
50/50 odds if you're a betting type!
The Following User Says Thank You to jbfan For This Useful Post:
stickboy1375 (09-18-2013)
Old 09-16-2013, 07:11 PM   #17
Rewards Points: 2,512
Yes it is. A lot of ifs in that scenario.
hammerlane is offline   Reply With Quote
Old 09-16-2013, 08:19 PM   #18
Rewards Points: 1,192
Never could dig doing electric finish before drywall is done.
bobelectric is offline   Reply With Quote
Old 09-17-2013, 06:53 AM   #19
PoleCat's Avatar
Rewards Points: 1,646
We used a red caulk for fire stops. Easier to control than foam and easy for the inspector to see.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-17-2013, 07:09 AM   #20
Rewards Points: 720
Violation for cables stapled closer than 1-1/4" to edge of framing member.
Mark
busman is offline   Reply With Quote
Old 09-17-2013, 07:11 AM   #21
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Mark
Still a violation with the other side already finished? Just playing devils advocate on this one.
Honestly, with 2x4 framing, its still an issue even in the middle of the stud, siding guys only use one size nail, long ones...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (09-18-2013)
Old 09-17-2013, 07:39 AM   #22
Rewards Points: 720
It could be a problem when the outside finish material is replaced. If it's just painted, I've still seen nails/screws added where the sheathing has pulled away from the studs. No reason not to just use some stack-its and do it right.
Mark
Old 09-17-2013, 10:22 AM   #23
joed's Avatar
Rewards Points: 11,614
Why? I could use a nail to support my wires, is someone going to tell me I can only have one wire under a bent over nail?
Not in Ontario you couldn't.
Old 09-17-2013, 05:35 PM   #24
E2 Electrician
You are mandated to use a staple that was designed for NM cable?
Old 09-17-2013, 05:36 PM   #25
E2 Electrician
Mark
I agree, i'm just saying with 2x4 construction, good luck even with a stack it...
Old 09-18-2013, 10:24 AM   #26
joed's Avatar
You are mandated to use devices that are specified for the job they are being used for. Nail are not sold or tested for use as cable straps just like you can't use water line PVC for conduit.
Old 09-18-2013, 11:31 AM   #27
JOATMON
ddawg16's Avatar
Rewards Points: 852
Originally Posted by hammerlane View Post
Grounding hole can go up.
Look at it this way:
If you have something plugged in and something hanging on wall above the plug. If plug is partially out and the something on the wall falls(like a metal picture frame) the metal frame would first hit the ground prong of the plug instead of shorting out across the hot and neutral prong of the plug.
Next time you are in a hospital look how their receptacles are oriented.
Or, a knife....but then again, the likelihood of the object staying perfectly balanced on that ground prong is pretty slim....hence you have a 50/50 chance on which way it will tilt. If it tilts to the right...it will contact the neut blade....
If it tilts to the left, it will hit the hot blade of the plug....and depending on how your ground wiring is, it could energize your ground ckt creating an ever bigger problem....
So...the moral of the story is, going to the left is bad...going to the right is good.
Old 09-18-2013, 07:45 PM   #28
E2 Electrician
This isn't required in the NEC, so nails would have to be accepted.... as long as the cables are properly supported, not much else is required.
Old 09-18-2013, 10:27 PM   #29
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
You got caught in a classic troll trap.
Old 09-19-2013, 04:08 AM   #30
kbsparky's Avatar
I see two wires under one staple. Is that staple rated for two wires. If not then it will fail.
They will only fail if they were made in Canada. US staples will work just fine....
-KB
How to mend underground sprinkler electrical wire diyatx Electrical 1 02-28-2013 02:47 AM
Fishing PEX through walls like electrical wire? Pele2048 Plumbing 1 02-20-2013 06:01 PM
Four wire electrical + ceiling fan ja0019 Electrical 14 05-09-2010 11:31 AM
Electrical wire size question. shawnlee Electrical 11 08-11-2009 07:25 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
