Look Of Electrical Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 08:41 AM   #1
Rewards Points: 41
Look of electrical wire
I wired some outlets and was wondering if it looks okay. This house had very little wiring in it so I had to drill the holes and run new wire. Is the wire to low to the ground or anything else. Is this what you normally see in new construction?
Look of electrical wire-imag1302.jpg   Look of electrical wire-imag1303.jpg   Look of electrical wire-imag1304.jpg   Look of electrical wire-imag1305.jpg
biddlecom is offline   Reply With Quote
Old 09-16-2013, 08:56 AM   #2
Rewards Points: 13,300
In that first picture it looks like the insulation is not up inside the box.
Not sure what your local codes call for but here we can use 15 amp outlets even if there's 12-2 wiring which can save a bunch of money and not effect safety.
Does that outlet that you have three wires running to have a clamp on the side for two wires or just a screw?
You can only have one wire per screw.
Old 09-16-2013, 09:35 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
The grounding hole is down instead of up. So that is correct.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
bbo (09-16-2013)
Old 09-16-2013, 10:06 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
it looks like you have some holes through the toe plate. If you are abandoning those holes (or any holes running vertically through the floor for that matter), you'll need to fill them with foam or something.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-16-2013, 11:09 AM   #5
Rewards Points: 2,516
Grounding hole can go up.
Look at it this way:
If you have something plugged in and something hanging on wall above the plug. If plug is partially out and the something on the wall falls(like a metal picture frame) the metal frame would first hit the ground prong of the plug instead of shorting out across the hot and neutral prong of the plug.
Next time you are in a hospital look how their receptacles are oriented.
hammerlane is offline   Reply With Quote
Old 09-16-2013, 11:16 AM   #6
Electrical Contractor
jbfan's Avatar
Yea, Yea, Yea. This debate can go on for years.
The falling object could very well hit the ground pin and the hot side and cause a fireworks show!!!
The only thing I do different is run my wires higher and go into the top of the boxes.
I don't like to work on my knees anymore than I have too.
jbfan is online now   Reply With Quote
Old 09-16-2013, 11:56 AM   #7
joed's Avatar
Rewards Points: 12,008
I see two wires under one staple. Is that staple rated for two wires. If not then it will fail.
Old 09-16-2013, 12:01 PM   #8
Rewards Points: 82
Looks fine. Better than some professionals! Good job.
Old 09-16-2013, 01:16 PM   #9
Does that foam (or something) need to be fire rated? (I am thinking yes.)
oberkc is offline   Reply With Quote
Old 09-16-2013, 01:27 PM   #10
I have gas!
Good Point, Great Stuff has a fireproofing foam.
Old 09-16-2013, 04:10 PM   #11
Rewards Points: 342
looks real profesional! like jbfan said the ground up or down is an ongoing debate.
circuitman is offline   Reply With Quote
Old 09-16-2013, 05:10 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why? I could use a nail to support my wires, is someone going to tell me I can only have one wire under a bent over nail?
Old 09-16-2013, 05:30 PM   #13
bbo
is the nail rated for two or one wire?
Would Mike Holmes use a screw in this case?
bbo is offline   Reply With Quote
Old 09-16-2013, 05:31 PM   #14
E2 Electrician
I think the OP did a fantastic job as well btw....
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (09-16-2013)
Old 09-16-2013, 05:33 PM   #15
E2 Electrician
Pretty creative scenario, no?
How to mend underground sprinkler electrical wire diyatx Electrical 1 02-28-2013 02:47 AM
Fishing PEX through walls like electrical wire? Pele2048 Plumbing 1 02-20-2013 06:01 PM
Four wire electrical + ceiling fan ja0019 Electrical 14 05-09-2010 11:31 AM
Electrical wire size question. shawnlee Electrical 11 08-11-2009 07:25 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
