Longest Run - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 03:38 PM   #1
longest run
from farthest downstream outlet
to load center
for a residence?
Would this be using #12 or #14?
Old 06-09-2010, 03:43 PM   #2
What exactly are you asking ?
You could make a longer run with #10 if you wanted to
Or an even higher gauge
Old 06-09-2010, 06:06 PM   #3
Using copper or aluminum, #12 or #14, how long can the Romex be from the load center to the farthest outlet?
If I'm allowed a 3% drop at 120v, at what max current would this be?
Old 06-09-2010, 06:17 PM   #4
Voltage drop calculator
It would be different for each gauge
And would depend upon the load at the last outlet
Around 65' for 12-2 w/15a load at the last outlet
Voltage drop Calculator:
http://www.csgnetwork.com/voltagedropcalc.html
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Yoyizit (06-09-2010)
Old 06-10-2010, 03:29 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Yoyizit.,
Typically for longest run with 4.0mm˛ with 15 amp load @ 120 volts will be about 25 meters depending how steep the voltage drop you want to be set at normally I set at 3% the most but some load which it is not circital it can able toralce up to 5% but no more than that.
Merci,Marc
Old 06-10-2010, 06:28 AM   #6
Rewards Points: 502
I'm pretty sure there are loads that can handle more than 5% voltage drop without a noticable effect. for example, a quality computer PSU can handle input voltages down to about 90volts. The pool pump I am replaceing is dealing with about 7% based on the above calculator. I've also run several power tools on extention cords chained together pretty far away from an outlet (some chained out beyond the 7% outlet mentioned above). I bet incandecent light can drop quite a bit too before you notice a big difference.
forresth is offline   Reply With Quote
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 40 03-21-2016 06:57 PM
Which Interior Paint will Last Longest saggdevil Painting 5 05-08-2012 03:09 AM
Whats the longest sheet of drywall you have gotten thru egress window? bkeech Drywall & Plaster 12 02-05-2010 10:32 AM
What is the heaviest and longest hand auger that is practical? darsunt Plumbing 1 08-17-2009 10:29 PM
