Long Winded Electrical Question - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-16-2014, 08:20 PM   #31
Rewards Points: 3,256
Originally Posted by gregzoll View Post
There was no 120 vAC involved on the end that the cooler plugged into the Invertor.
I'm not going to waste my time spoon feeding you. Perhaps you should take a reading comprehension course.
zappa is offline   Reply With Quote
Old 06-16-2014, 09:22 PM   #32
Rewards Points: 6,652
Originally Posted by sgip2000 View Post
This thread is exactly why the NEC exists and why inspections are required, lol.
12v, 120v, it's all voltes, right?
This has nothing to do with the NEC.
Old 06-16-2014, 09:22 PM   #33
Excuse me. Looks like you need to be spoon fed. Along with going back and reading the complete post from the OP.
Old 06-16-2014, 09:29 PM   #34
Rewards Points: 332
I'm awareof that. I was just saying that this is an example of why the NEC and inspections are necessary.
Sent from my SM-N900T using Tapatalk
sgip2000 is offline   Reply With Quote
Old 06-16-2014, 09:40 PM   #35
Again, the OP post has nothing to do with the NEC. Inspections yes, for frayed or signs of melting on the plug end of the cord, and connector in the side of the cooler for burnt or melting.
There is really not much to these thermocoolers. Simplistic design at their finest. As I stated also before. If you do a search on "Coleman thermocooler cord melted". You will find a plethora of threads on these coolers having the same issue. Coleman knows about it. That is why they have the repair parts available at camping places, and truck stops.
Old 06-17-2014, 04:41 AM   #36
An old Tradesmen
Rewards Points: 7,830
Again for the 400th time. The third party was using a Power Invertor that is made for these coolers.
Go back and read the original post.
While the friend didn't plug it into a 120 outlet. The OP inserted the wires he stripped from the 12 volt power plug into a 120 volt outlet. Which is why the cooler is toast now.
From the OP.
I also wanted to see if the cooler fan would still work, so I "tried" plugging the 2 bare wires that I unsheathed, into a house outlet....got a lot of sparks, so decided maybe I was literally playing with fire here, and could end up doing more damage to the motor and fan than anything else.
The Following 4 Users Say Thank You to beenthere For This Useful Post:
de-nagorg (06-17-2014), electures (06-22-2014), Msradell (06-17-2014), zappa (06-17-2014)
Old 06-17-2014, 06:14 AM   #37
beenthere, you just cannot fix it. Trying to plug a 12 vDC appliance into a 120 vAC outlet. Speaks Darwin awards. I do believe this thread has ran its course at this time.
Old 06-17-2014, 06:56 AM   #38
Rewards Points: 44
Again, Greg didn't read the full post. #4 it can't be fixed, #8 it can be fixed.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
stickboy1375 (06-17-2014)
Old 06-17-2014, 07:17 AM   #39
Bill Kearney
Rewards Points: 1,174
In the OP's original post he also wrote that he'd plugged it straight into 120vac.
wkearney99 is offline   Reply With Quote
Old 06-17-2014, 07:37 AM   #40
Yes and this thread has ran its course. Again. You just cannot fix you know what.
Old 06-17-2014, 03:55 PM   #41
An old Tradesmen
In post #12 I said that its toast. Right after I read that he put the wires into a 120 volt outlet.
Not a Darwin award action. Just someone that didn't know how it worked, and failed to ask here if that would be a good way to test it. A mistake the OP probably won't make again in the future on any device.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
micromind (06-17-2014), stickboy1375 (06-17-2014)
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Snowblower Electrical Question TimKLL Automotive Repairs 3 01-20-2011 07:10 PM
Old Electrical Box Insurance Question bailey35 Electrical 4 06-29-2010 01:58 PM
Electrical socket question hayzen Electrical 2 01-15-2010 02:16 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
