"AND" Logic Light Switch To "OR" Logic - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 07:14 AM   #16
Rewards Points: 506
Originally Posted by thadsaab
I think your "logic" is better than the OP's. It sounds like the OP wants a standard 3-way switching arrangment, which isn't "OR" it's "XOR".
The correct logic is "IF-THEN".
jlmran is offline   Reply With Quote
Old 04-28-2011, 11:38 AM   #17
Wow, I didn't expect a logic lesson here, but I appreciate it. Yes, either switch on = on is kind of silly. All I want is the light to change status when I flick a switch, regardless of switch position.
I'll check all the colors tonight and get back on here if I have any issues. I appreciate the help.
wcpatton is offline   Reply With Quote
Old 04-28-2011, 11:43 AM   #18
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
My bad, I'm used to coding, so when I seen OR I figured two switches in parallel. haha. Yeah 3 way is what you want. They can be a bit tricky. First thing is to know what screw on the switch is what, sometimes it's not labeled right and the side does not always matter. Play around with the switches using crocodile clips, a bulb or other load and low voltage source so you can better know how to connect it. Then find out where each wire in the box goes. Then you can figure out from there.
Old 04-28-2011, 12:03 PM   #19
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
logic gates.
actually an XOR is the proper gate to provide the actions of a 3 way switch setup. While thadsaab properly identified it, jlmran spoke to the function of a logic gate.
the truth table for an XOR gate is
a b c
0 0 0
1 0 1
0 1 1
1 1 0
with a and be being inputs (analogous to switches) and c being output.
Old 04-28-2011, 12:05 PM   #20
nap
You talking to me?
nap's Avatar
My bad, I'm used to coding, .
coding? is that what you do?
familiar with C++?
arduino controllers?
Tags
light switch logic
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
