"AND" Logic Light Switch To "OR" Logic - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 02:10 PM   #1
Lightbulb
"AND" Logic Light Switch to "OR" Logic
I am sure there's a name for this, but I have no idea what it would be.
Basically, I have a light connected to two switches. To turn on the light, both need to be ON. Either switch off turns off the light. I'd like to make it work so the light could be turned on by either switch.
wcpatton is offline   Reply With Quote
Old 04-27-2011, 02:33 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Describe the wireing inside both switch boxes.
Sounds like a traveler may be misswired.
Old 04-27-2011, 02:35 PM   #3
fabrk8r
fabrk8r's Avatar
Google "3-way switch"...and I agree with jbfan
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-27-2011, 02:44 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
wcpatton; what it sounds like you have at the moment is a pair of spst switches wired in series. if you have only spst switches, you can control the on function as you desire but the off function will be still be an "and" function.
You need, as fabricator intimated, a set of 3 way switches and the appropriate wiring between them.
if you already have 3 way switches, then they are simple wired incorrectly. If so, as jbfan asked, explain the situation in the switch boxes.
Old 04-27-2011, 04:41 PM   #5
It looks like Black wire on one side, other side has white and red.
Old 04-27-2011, 04:49 PM   #6
jbfan's Avatar
Rewards Points: 554
On both switches?
Old 04-27-2011, 04:59 PM   #7
Yes, on both.
What I'm looking for is to be able to flick the switch and have the light change either on or off, regardless of which direction the switch is.
Old 04-27-2011, 05:44 PM   #8
nap
You talking to me?
nap's Avatar
Ok, so it sounds like you do have 3 way switches. Now, you need to do some investigation.
ignore the wire colors in the pic as they may not coincide with what you have.
The two screws with a common color (usually brass or silver) are for the travelers. The (usually) black screw is for the hot feed on one end of the circuit and switch leg to the light on the other end of the circuit. I have seen a switch that had both travelers on one side of the switch so just use the screw color to determine which is which.
Old 04-27-2011, 05:51 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Yes, on both.
You have a misiwred 3-way setup. That's all.
It WILL work as you want once it is corrected.
A 3-way switch has no "on" or "off" position.
Old 04-27-2011, 06:30 PM   #10
Just call me Andrew
Rewards Points: 1,020
This animated diagram should help you understand 3-way switches:
Andrew
secutanudu is offline   Reply With Quote
Old 04-27-2011, 06:44 PM   #11
Is that a "Bud" Light??
The Following User Says Thank You to Speedy Petey For This Useful Post:
secutanudu (04-27-2011)
Old 04-27-2011, 06:50 PM   #12
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
If you just want a "OR" logic I'm guessing you want it so if any or both switch are on, the light is on?
If yes, two standard switches in parallel should do this. A 3 way circuit makes more sense though but guess it depends on your situation.
Old 04-27-2011, 06:53 PM   #13
Just call me Andrew
Squirrel...looks like he wants to be able to toggle the state of the light (on/off) from either side....so he needs a 3-way. That's how I interpret it at least.
Andrew
Old 04-27-2011, 07:21 PM   #14
joed's Avatar
Rewards Points: 13,354
If you only have three wires in each switch then you will need to use a voltage tester to find the hot lead. One of the wires in one of the switches will be always hot to ground.
If you don't have a voltage tester then tell us the wires in the fixture as as ALL the wires in the switches.
Old 04-28-2011, 07:11 AM   #15
I think your "logic" is better than the OP's. It sounds like the OP wants a standard 3-way switching arrangment, which isn't "OR" it's "XOR".
thadsaab is offline   Reply With Quote
Tags
light switch logic
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
