"Locator Light" Flickering On Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 02-12-2013, 12:16 AM   #1
"Locator Light" flickering on light switch
For the only 2 light switches that control the lights up the stairs to the second floor in my home, both switches have a "locator light" feature -- if you're not familiar, or the feature may go by different names, this is just a feature where an LED light illuminates around the light switch when it's off. It's probably for safety since it's for the stairs in the dark, etc.
The problem: Recently I noticed that the LED on the switch at the bottom of the stairs has been flashing when the lights are off (the LED light is supposed to stay on solid orange, instead it flickers randomly). I thought it might be the power on the whole switch, however, the other switch at the top of the stairs that controls the same lights is just fine. No flickers, just a solid LED border around the light switch when in the OFF position -- just like I would expect.
So my question is, what would be the prudent steps to troubleshoot this? Should I just try to replace the light switch? Are these "locator light" LEDs known to go out?
Any help or advice would be greatly appreciated. Thanks.
ferrugia is offline   Reply With Quote
Old 02-12-2013, 12:36 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
What type of lamps (bulbs) do you have on the fixture that these switches control. Lighted switches like you have often do not play well with CFL or LED lamps.
BTW, the light source in those switches is usually a neon lamp not LED.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 02-12-2013, 01:02 AM   #3
Rewards Points: 6,652
Yes, those bulbs do flicker, especially once they get old, or as stated above, if you are using a CFL or LED bulb in the fixture. If you want a night light, and you do not have a "Switch leg", use one of these http://www.cableorganizer.com/levito...ght-light.html Kind of pricey, but you do not have to worry about someone leaving the light on, when leaving the stairway area.
Old 02-12-2013, 02:26 PM   #4
Thanks for the response. The strange thing is that the bulbs are just regular 60W bulbs, nothing fancy like LED lamps. This is just a plain-jane light fixture that these two switches control with old-school bulbs in it. The switch at the top of the stairs does not flicker, but the one at the bottom does.
Thanks for the clarification on the light source in the switch. I assumed LED but wasn't sure. Thanks.
Old 02-12-2013, 02:28 PM   #5
Some actually are going to LED, due to they do not give off heat, and use less voltage when the lights are off, but the switch is lit.
Old 02-12-2013, 02:31 PM   #6
Thank you for the response as well. I think you are saying the same thing but just to be clear this is the "bulb" in/around the light switch that I'm referring to -- I'm NOT talking about a flickering coming from the lights/bulbs that these switches control.
This is not really used as a night-light so much as the fact that when it's pitch dark you can see where the switch for the light is.
The weird thing is that the light switch is not that old. Maybe 3 years old. Since the one at the top of the stairs doesn't flash though, and they must be on the same circuit since they control the same light, I guess my next step is to buy a new one this weekend and see if it fixed the problem when I use it as a replacement.
Thanks very much for the responses. Much apprecaited.
Old 02-12-2013, 02:34 PM   #7
Again, regardless of the age of the switch, they go bad. I have seen electrical devices bad out of the box, and bad within a couple of months. Stuff is not made like it used to be, when made here in the U.S., where standards were higher, than those in Mexico & China, where the majority of stuff is manufactured these days.
Old 02-12-2013, 02:36 PM   #8
Ok, I understand and agree with you. Replacing the switch should be cake. Now the difficult talk will be trying to find the same one so it matches the rest of them in my house. When I get the switch off, is the manufacturer and part # usually there and visible? Just trying to think ahead on what the best way to match this will be. I didn't do the initial installation a few years back, the people that we bought the house from did and are long gone (so I can't ask them). Thanks again.
Old 02-12-2013, 02:52 PM   #9
Take the old one with you. You could also check online through Amazon.com to see if they have something close to it, if you can not find at your local Lowe's, Home Depot, Ace Hardware.
With Leviton & Pass & Seymour being the two main brands, you are usually stuck with only certain styles, and most stores will either carry the Decora in either residential or Commercial, and same for the standard lever switch.
Old 02-12-2013, 09:42 PM   #10
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
I don't think you REALLY want to buy the same brand, especially if this one isn't very old- once burned twice shy as they say!
I have one of those switches and in a few months or less it's little light started flickering, they are junk. Get a regular switch and a plug-in nightlight which is real easy to replace the little bulb for.
Every time you replace a wall switch or outlet you have to pull all the wires out of the cramped little box with it, do that a few times and you weaken the wires from bending them back and forth, you already don't know how MANY times that switch had been previously replaced.
RWolff is offline   Reply With Quote
Old 02-12-2013, 11:38 PM   #11
dmxtothemax's Avatar
Rewards Points: 5,102
It is normal for neon indicator lamps to flicker a little,
They usually use very low currents, usually 500 micro amps.
So any leakage in the circuit will induce a small voltage
that will cause the neon to flicker.
Tom153 likes this.
dmxtothemax is offline   Reply With Quote
Old 02-13-2013, 12:21 AM   #12
Good news, I got it working tonight with a new 3-way lighted switch that I picked up at Home Depot.
I was fortunate in that Home Depot had the same one (or very similar) made by Leviton so it matches the existing ones I already have in my house that are working -- I didn't want to replace them all or have mismatches. Ya, I can see that it's assembled in Mexico and I would rather have German, but it was $7 and the problem is solved so I'm happy. If these keep breaking I will switch to something else next time. Glad not to have that annoying flickering in the dark anymore.
Re-wiring the 3-way switch was easy, there are Youtube videos that make it so simple. It look less than 5 minutes. Very easy DIY.
Thanks to everyone who contributed input. I hope this can help someone else in the future.
Old 12-02-2016, 08:15 PM   #13
Rewards Points: 20
Re: "Locator Light" flickering on light switch
I have a similar problem. I have a hall light that was an old screw in CFL. The two switches have a neon light in them that illuminates when the hall light is off. No flicker in the neon illuminated switches. Then I changed out the old light fixture with a Commercial Electric Edge-Lit LED flushmount. The light works great, but now the neon lights in the switches flicker. I'm just wondering why they flicker and if it is a fault condition that needs to be corrected.
Tom153 is offline   Reply With Quote
Old 12-02-2016, 09:36 PM   #14
Some types of bulbs/switchs with electronics in them
( CFL & LED ) will allow very small currents to pass
This is what causes the flickering.
MTN REMODEL LLC and Tom153 like this.
The Following User Says Thank You to dmxtothemax For This Useful Post:
Tom153 (12-02-2016)
Old 12-02-2016, 09:59 PM   #15
Rewards Points: 20
Ok, makes sense do you know of any replacement switch that is piloted that will not flicker? The flicker is annoying. I see Leviton has some newer switches with an LED pilot light, instead of a neon pilot light; do you know if they avoid the flicker problem?
MTN REMODEL LLC likes this.
Tags
flickering , locator light , switch
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
Need to add a light near switch in 3-way setup.... prosper50 Electrical 5 03-19-2011 10:19 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
