Location Of Subpanel In Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 05:30 AM   #1
Rewards Points: 135
Location of subpanel in garage
I will be pulling a 6/3 romex for a 60A subpanel in my attached garage. Since I am buying it by the foot I need to pick a location for the panel in order to buy only what I need. Are there any restrictions or guidelines as to where I can locate it? My ideal spot is on a sheetrock wall that has the dining area on the opposite side and the HVAC air handler around the corner from it. Any issues with this location?
elmaur is offline   Reply With Quote
Old 05-30-2012, 06:27 AM   #2
Code05's Avatar
Rewards Points: 1,104
#6 NM is only good for 55A, but as long as as the load does not exceed that you are okay.
No NEC restrictions, except height 6'7" max, but since you are penetrating the fire wall between the house and garage, ask your inspector about any IRC requirements or local codes on that issue.
Code05 is offline   Reply With Quote
Old 05-30-2012, 07:11 AM   #3
MarginallyQualified
Rewards Points: 2,464
No; you don't need to. You may not even want to.
In the overall scheme of things the cost for an extra 20 or 30 feet of feed wire is the least important factor in choosing a spot for the panel. Avoiding conflict with doorways and other fixture placement and then convenience for running circuits inside the garage is far more important.
Old 05-30-2012, 07:32 AM   #4
Code05's Avatar
elmaur, I was not really paying attention. Not enough coffee yet.
Where you mount the panel, there should be at least 30" wide clear space on the wall and nothing in front of the panel for 36".
There should be no other obstructions above or below the panel either.
I have a couple of pics that I will find and post showing what I mean.
The Following User Says Thank You to Code05 For This Useful Post:
elmaur (05-30-2012)
Old 05-30-2012, 08:54 AM   #5
Licensed electrician
Rewards Points: 1,278
While he goes to find the pics, imagine a refrigerator sized box in front of the panel as the amount of space you need.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Code05 (05-30-2012), k_buz (05-30-2012)
Old 05-30-2012, 09:00 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That is EXACTLY how I describe it to customers when quoting a service change and the washer/dryer is directly in front of the panel.
Old 05-30-2012, 09:09 AM   #7
Code05's Avatar
These are a bit much to swallow at once, but we can clarify as needed, basically - what Jim said.
Well phooey, the darn pics came out small.
Old 05-30-2012, 10:17 AM   #8
Rewards Points: 150
And then, after the inspection, you'll actually have space for a refrigerator in your garage.
silversport is offline   Reply With Quote
Old 05-30-2012, 11:13 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,158
That's ok as long as it has beer in it.....:beer:
As tarheel said, the cost of the wire is minor....just remember, you will have to wire from it to your outlets....
I installed mine by the man door....because I have the door there...I'm less likely to block the area....and I find it convinient to walk inside and just reach around the door to access the panel....which I do on a regular basis.
Click on the link in my signature...some fo the pics will show my meter..
And, yes....you are limited to 55A....I would feed it with a 50A breaker...the likelyhood of ever needing that much is very slim. Chances are I'm already using the same 60A panel....and I'm feeding mine with #6 THHN/THWN wire from a 50A breaker in my main load center.
ddawg16 is online now   Reply With Quote
Old 05-30-2012, 12:53 PM   #10
Rewards Points: 135
The person of authority I just spoke to did say if I am inserting the panel in the firewall then I need to have 1/2" sheetrock around the panel to maintain the firewall or surface mount it and seal all penetrations.
He also said 6/3 is okay for a 60A panel.
Old 05-30-2012, 01:02 PM   #11
Rewards Points: 135
Whether I am surface or flush mounting the panel my feed wire and circuits will be coming from above at a height of about 8 ft inside the sheetrock wall. Code05, one of your pictures shows conduit to the panel. if wires are inside the wall is conduit needed?
Old 05-30-2012, 01:10 PM   #12
Rewards Points: 135
HD price for 6/3 romex $2.64/ft. All things you mention I am considering but would hate to see $50 or more worth of wire sitting around unusable.
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
How to get 200 amp subpanel in garage chuck willis Electrical 17 03-22-2011 11:44 AM
Rewiring the house, garage subpanel question WillK Electrical 4 09-28-2010 11:14 PM
Yet another garage subpanel thread (w/ pictures!) MattOverMinder Electrical 9 07-25-2008 03:15 PM
