Location Of Receptacles In Kitchen - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 03:55 PM   #31
Rewards Points: 6,652
I wonder if they could get by with the pop-up outlets that are available, or use the in cabinet outlets, and have the appliances on pull-out type trays inside the cabinets, that when pulled out, you can pull them up to the counter height.
On the other hand, that whole pass through window probably seemed as a great idea at first, but now it is not looking that great, due to the headache it has created.
Old 07-04-2013, 05:48 PM   #32
joed's Avatar
Rewards Points: 12,862
The pop up outlets are not code compliant as far as I know. The only code solution is a solid mount tombstone style. In counter up facing receptacles are not allowed.
The only out you might is no receptacles. I believe the code might read "wall space' behind counter. There is NO wall space there.
Old 07-04-2013, 07:12 PM   #33
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It is my understanding that those windows count as wall space...just like an open railing in a loft type room would count as wall space.
Old 07-04-2013, 07:20 PM   #34
You are assuming that they are not code compliant how?
This will clear up any misconceptions about them. http://www.tnb.com/pub/node/1459 The GFCI receptacle is rated at 15 amps, 125 volts AC and 60 Hertz. It is compliant with UL 943, CSA C22.2 No. 144.1, NEC Section 210.52(C)(5) and NEC Section 406.5(E).
Old 07-04-2013, 08:17 PM   #35
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Absolutely. The "wall space" term is used for dimensions, regardless if there is a wall or not. Even in this case, there IS a wall, it just happens to be filled with very low windows.
Old 07-04-2013, 09:17 PM   #36
joed's Avatar
Rated at 15 amps? Don't you need 20 amps down there in the USA for kitchen receptacles?
Old 07-04-2013, 09:39 PM   #37
Yes, but all outlets on Kitchen circuits are 15 amp, but rated for 20 amp pass through. Only time I have seen a 20 amp outlet, is in a Commercial install, or a location where a homeowner may want to plug in a 20 amp rated device.
The 70 amp stick welder I have is rated at 20 amps, but uses a 15 amp plug on the end. Rarely do you find 20 amp plugs on devices. Even the buffers we used in the Navy on board ship all had 15 amp plugs, but were rated at 20 amps.
Old 07-05-2013, 09:17 PM   #38
Rewards Points: 1,628
I appreciate all the replies.
So if I go with something like this:
http://www.electricsuppliesonline.co...box-cover.html
I assume you will cut this square hole after the counter top has been installed instead of having it cut before delivery - like the large holes for the double sink?
Must be real tricky to cut a hole like this through granite. I bet a mistake could be really costly.
miamicuse is offline   Reply With Quote
Old 07-05-2013, 09:50 PM   #39
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If you know the location that they will be installed, I would definitely have the vendor cut the hole.
sublime2 is offline   Reply With Quote
Old 07-05-2013, 11:21 PM   #40
Oso954's Avatar
Rewards Points: 1,106
I believe I located the unit shown in usair's photo.
http://www.mockett.com/pcs39-ee-hw.html
While shown in black, it also comes in Satin Aluminum.
It is a hardwire unit, installs thru a 3"diameter hole.
You would need to add GFCI protection, either at the breaker or a unit below the counter.
Oso954 is offline   Reply With Quote
Old 07-06-2013, 12:27 AM   #41
At least the Carlon already has built in GFCI protection. As for that one, it would just have to be downstream of the gfci outlet on the chain on that wall, or yes, go with the breaker.
Old 01-03-2014, 01:46 PM   #42
lectric, nice job digging up old threads to get your spam links posted.
What's this, four so far?
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (01-03-2014)
Kitchen floor tiles. ABurch Kitchen & Bath Remodeling 1 12-06-2012 12:35 PM
Need help in re-designing tiny 1920's kitchen! PiscesWoman Interior Decorating 21 04-30-2012 03:25 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
Using same tile for bathroom and kitchen too Matchy-Matchy? Jeanene Interior Decorating 10 03-29-2010 12:38 AM
kitchen renovation - baseboard heat location tpagel Plumbing 7 03-14-2010 09:52 AM
