Location Of Receptacles In Kitchen - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 01:00 AM   #1
Rewards Points: 1,584
Location of receptacles in kitchen
On one side of my kitchen is an exterior wall that is about 9 feet across.
That wall has a window that runs pretty much across the entire length. The kitchen countertop will extend beyond the edge of the wall into the courtyard where the BBQ and swimming pool is. The kitchen window is one big horizontal sliding window containing multiple panes that can be slid open so you can serve food from the kitchen to the outside using the pass-thru counter.
The kitchen window will be sitting ON top of the countertop. Hence there is no backsplash area.
If I am standing in the kitchen looking at this wall with the wide window, I have receptacles on the left wall, and the right wall, but I have no receptacle in the middle.
There is no backsplash area to put receptacles. The window sits over the countertop. There is no top cabinets there because of the window. I have rough in a receptacle down below for the dishwasher and disposer.
Still I think it would be nice to have one or two additional receptacles across this space, but I am not sure where I could put them. Thoughts?
miamicuse is offline   Reply With Quote
Old 07-04-2013, 01:16 AM   #2
Rewards Points: 6,652
You will not be able to place any outlets there, due to your description of the window in the middle of the wall.
Now of course pictures in this thread really helps, and you should know that after 426, so that others have an idea of what you are talking about.
Old 07-04-2013, 02:56 AM   #3
Rewards Points: 416
Install two 1800 watt 6 outlet power strips, spaced to your satisfaction, in the counter top under the window, connected to GFCI power, and you'll have plenty of outlets.
Old 07-04-2013, 05:50 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The typical solution is to install Plugmold just under the front lip of the counter.
The Following User Says Thank You to k_buz For This Useful Post:
MTN REMODEL LLC (07-04-2013)
Old 07-04-2013, 06:06 AM   #5
Rewards Points: 12,818
Could also use Tombstone outlets on top of the countertop.
My inspector would not except any outlets installed on the face of the cabinets. Due to the danger of cords being caught as someone walked past.
No flush mounted outlets on a counter top ether.
Old 07-04-2013, 06:18 AM   #6
k_buz's Avatar
Your inspector is an idiot and unless your community had it in writing, I would have fought that. Does he require the same for a peninsula or an island? Does he/she waive the requirement for an receptacle in a hallway? Someone could walk by and hit a cord while walking down the hall.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
frenchelectrican (07-04-2013), Philly Master (07-04-2013), Speedy Petey (07-04-2013)
Old 07-04-2013, 08:15 AM   #7
k_buz's Avatar
What are you talking about?
Old 07-04-2013, 10:03 AM   #8
Rewards Points: 150
try a pop up receptacle
RIP EJT
usair is offline   Reply With Quote
Old 07-04-2013, 10:11 AM   #9
Rewards Points: 416
http://www.uline.com/Product/Detail/...A&gclsrc=aw.ds
Old 07-04-2013, 10:14 AM   #10
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,386
Attachment 73460
Us.... Cool... never seen it.... I assume it's code compliant.... does it have a name/maker
MTN REMODEL LLC is online now   Reply With Quote
Old 07-04-2013, 10:20 AM   #11
k_buz's Avatar
Yeah, that isn't even close to a correct suggestion.
Old 07-04-2013, 10:20 AM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
You're joking, right?
If not then please refrain from giving any further electrical advice.
Speedy Petey is online now   Reply With Quote
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (07-04-2013), k_buz (07-04-2013)
Old 07-04-2013, 10:43 AM   #13
chitownken's Avatar
Rewards Points: 510
www.mockett.com
They have 6 foot plug end cords attached. They are UL and CSA listed. I have 2 of these http://www.mockett.com/technology-in...6-ee-m-90.html in my island with the cooktop. They are on a GFCI breaker and they plug into an outlet inside the island cabinet where the cooktop plugs in. Inspector was OK with it as long as the plugs were accessible and it was GFCI protected.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
Old 07-04-2013, 10:50 AM   #14
k_buz's Avatar
Highly doubt those would fly with an inspector. UL listed doesn't necessarily mean legal. For a desk or movable piece of furniture...yes. For a counter top...no.
Old 07-04-2013, 10:54 AM   #15
chitownken's Avatar
Rewards Points: 510
Was concerned about that myself, but it passed inspection here. Check with your local code officer first.
Kitchen floor tiles. ABurch Kitchen & Bath Remodeling 1 12-06-2012 01:35 PM
Need help in re-designing tiny 1920's kitchen! PiscesWoman Interior Decorating 21 04-30-2012 04:25 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 08:59 AM
Using same tile for bathroom and kitchen too Matchy-Matchy? Jeanene Interior Decorating 10 03-29-2010 01:38 AM
kitchen renovation - baseboard heat location tpagel Plumbing 7 03-14-2010 10:52 AM
